XK8 2001 Antenna broke
Old Aug 26, 2021 | 01:10 PM
Markmbaha1's Avatar
Default XK8 2001 Antenna broke
My antena got mangled (long stupid story), what stops the motor from running either up or down? It is still attached and seems to partly go up and stop and partly do down and stop. As soon as it stops the motor stops. I'm hoping I can simply thread a new mast into it as I've read. Thoughts?
Old Aug 26, 2021 | 02:45 PM
Welcome to the forums Markmbaha1,
As you've posted a separate Intro, I've moved your question from New Member Area - Intro a MUST to XK8/XKR forum. Members here with the same model will be able to help.
You will be very unlucky if it is anything more than a new mast required although sometimes the motor unit has to be opened up to retrieve a broken end of the toothed drive.
Old Aug 26, 2021 | 03:31 PM
Markmbaha1's Avatar
Thank you so much. When I pulled all the trunk cosmetic covering pieces I realized in front of the antena is the cd player, the cd amplifier and the hydraulics for the convertible top. I'm hoping threading the mast down in, will work. Otherwise its going to have to go to the dealer. Thanks again.
bwryan
Jul 1, 2021 10:40 PM
deelli
Dec 19, 2016 10:56 PM
Tri_motorman
Jan 14, 2015 03:08 PM
reelpirate
Jun 23, 2010 09:58 AM
