Xk8 2003 DSC/ABS problems
Old Feb 5, 2025 | 07:05 AM
Zmac888's Avatar
Default Xk8 2003 DSC/ABS problems
Hi, 03 4.2 n/a XK8 i've had DSC not available and ABS light on for some time. Changed all the sensors, changed one loom and proved the rest work as was getting front left sensor code this didn't resolve it. Then I had the ABS module refurbished by and ECU repairer. Put it back on and bleed the system now getting C1285 and C1288 codes which won't clear and had a rear sensor code which cleared. I charged the battery as it had been stating for a while, as i was having some welding done the the sills, still won't clear down. Any clues on why these codes would present after changing out the module?
Old Feb 5, 2025 | 08:07 AM
motorcarman's Avatar
Brake Booster faults.
File Type: pdf
Old Feb 5, 2025 | 09:49 AM
Zmac888's Avatar
These codes didnt come up before why now? Would my previous issues with the sensor codes be because of the brake pressure and solenoid failing, or could it be a short in the wiring loom?
user 5722353535
Dec 18, 2021 12:27 AM
Diederick
Nov 10, 2020 10:10 AM
coastmobility
May 17, 2016 07:46 AM
Peperami
Mar 31, 2015 06:32 AM
joeboat84
Jan 27, 2014 01:09 PM
