XK8 ABS pump wiring
Old Feb 3, 2020 | 11:44 AM
warren8959's Avatar
Default XK8 ABS pump wiring
Has anyone replaced damaged wires on the leed from the ABS motor to the ATE harness? I can see the wires connect to the harness using a connector, but can the wires be disconnected at the ABS motor or is it necessary to remove the motor and solder the replacement wires internally? I've searched and cannot find any info on how the wires attach to the ABS motor. Thank You. 1999 XK8 Coupe
Old Jan 21, 2024 | 05:06 PM
oldjaglover's Avatar
Did you ever locate and pull the multi-pin connector??
jhshannon
May 14, 2023 04:02 PM
Jeff.Jag
Jan 26, 2020 12:23 PM
kenatofc
May 13, 2017 04:18 PM
Spurlee
Sep 30, 2016 05:59 PM
Joffa
May 14, 2009 08:23 AM
