XK8 alarms tries to start dies
Old Nov 18, 2013 | 06:06 PM
tctathome's Avatar
Default XK8 alarms tries to start dies
1998 XK8 set alarm with remote, but drivers door latch does not pull in.
Passenger latch cycles few times, then alarm sounds. Unlock all with key
and engine cranks and tries to start, but after a second or two at about
100 rpm it dies. Checked all fuse in both door areas and in the trunk
fuse box. Swapped fuel relay with other relay. Can feel fuel relay activate
and voltage goes through #7 20 amp fuse. Tried both ign keys, same result.
Any ideas??
Old Nov 18, 2013 | 07:40 PM
Welcome to the forum tctathome,
I've moved your question from XK/XKR 2006 onwards to XK8/XKR 1996-2006 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Nov 19, 2013 | 06:54 AM
RJ237's Avatar
Welcome to the forum. I can't offer any assistance on the door lock issue, but the non start is at this time probably due to bore wash.
Use the search function to get more info on bore wash or cylinder wash. The fix is to remove at least the four spark plugs on the right bank (easier) and put about 1/4 teas. oil in each cylinder. Place a rag over the head and turn the engine over a few seconds with the accelerator depressed all the way to distribute the oil. After cleaning the oil sprayed out the holes, put the plugs and coils back and try to start. Be ready for a lot of oil smoke.
If it still doesn't start, you may have other problems. Check list below:
JagRepair.com - Jaguar Repair Information Resource
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
philwarner
Sep 3, 2015 10:14 PM
David Thompson
Sep 3, 2015 07:48 PM
