XK8 brake improvements
Old Oct 31, 2013 | 09:46 PM
Bad Cattitude's Avatar
Default XK8 brake improvements
My wife has been borrowing my S-Type R for errands, etc. while her XK8 is getting repainted. Today she got back in her car for a short drive after we got the convertible hydraulic system flushed and afterward she remarked how weak her XK8 brakes felt in comparison to my car.
I explained to her that my car was more performance oriented (Brembo) and that I would see what I could do to improve the feel of her car. So far, you may recall I flushed and bled her braking hydraulics to improve the mush pedal. I am asking if you can recommend pads with more of a 'bite' than stock.
Thanks in advance!
Old Nov 1, 2013 | 10:27 AM
aode06's Avatar
How much that convertible fluid change cost ?I need mine done it aint the colored stuff
http://www.jagwebworld.com/wp-conten...cs-Growler.pdf
and here for the padshttp://ebcrotors.com/p-220-ebc-redst...SeeYourOptions
they also sell the rear pads
Here you go btw, also lower her tire pressure to 28 psi all the way around, that how the dealer did mine.It was in the instruction manual, and improved stopping and wet traction
Old Nov 1, 2013 | 11:55 AM
CoventryCars's Avatar
Perhaps changing out the factory rubber flex brake hoses for aftermarket teflon/stainless flex hoses might reduce some of that 'spongy' brake feel.
I replaced my old solid rotors with new cross-drilled, slotted rotors, and sets of ceramic pads. Seems to have helped with better stopping and heat dissipation. Less brake dust build-up too!
Old Nov 1, 2013 | 12:08 PM
and here for the padsEBC Redstuff Brake Pads | Redstuff Low Dust Performance Brake Pads
$200.00 at my local independent shop.
Old Nov 1, 2013 | 06:22 PM
aode06's Avatar
hell, his hoses may be bad, they are what over ten years old?
When I get new rubber, I buy heat shrink at home depot-big ones, slide it over the rubber, shrink away., light coat of black rtv over that tube, put new one on, shrink away.
makes the life INFINITE
Old Nov 1, 2013 | 09:01 PM
I don't feel and mushiness with the pedal after the hydraulic fluid flush. I think she's just spoiled by the feel of the STR brakes. I will try the upgraded brake pads.
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
Aus V8S
Nov 13, 2015 11:01 AM
Jefro
Sep 15, 2015 01:44 PM
jagent
Sep 12, 2015 09:10 AM
