xk8 conv back windows stopped working
Old Jul 14, 2016 | 10:13 PM
kwheat's Avatar
Default xk8 conv back windows stopped working
2004 sk8 conv. both back windows stopped working at the same time when I lowered the top. They are half way down, stuck. It sounds like there is something trying to work on both sides when I try to operate them but nothing moves.
Old Jul 15, 2016 | 08:42 PM
Vector's Avatar
Welcome to the forum!
You can try a "hard reset."
Remove both terminals from the battery and touch them together for 10 seconds, reconnect them and then start the car.
Try the windows/top operation after a short drive.
If that doesn't work, the roof closing sequence may be out of sync. You may have to re-program the windows for convertible top operation. I don't recall the procedure, but a search should locate it for you.
Vector
Old Jul 15, 2016 | 09:22 PM
kwheat's Avatar
Default windows stopped working
Thanks. I can hear both sides trying to work at the right time but nothing moves. Do you think this is a reset problem. I'm going to try your suggestion. Will let you know.
Gmorris430
19
Mar 17, 2019 04:05 PM
Lagonia
Jun 14, 2016 09:32 PM
gallstar
May 9, 2016 08:20 PM
sanchez
Apr 25, 2016 05:47 PM
doowopfix
Apr 22, 2016 10:56 AM
