xk8 convertible trunk
Old Apr 3, 2026 | 02:14 PM
66RBS's Avatar
Default xk8 convertible trunk
Are there truck shocks that will open the XK8 trunk completely. Not just ajar by 1"
Randy
Old Apr 3, 2026 | 03:33 PM
MVMonarch's Avatar
Unless you could find a motor-driven strut, a pair of struts strong enough to lift the boot cover to fully-open would make it very difficult to close.
Old Apr 3, 2026 | 05:37 PM
zray's Avatar
On my 2002 XKR the trunk will open the one inch using any of the trunk releases. Just subsequently touching the trunk, even slightly, will cause it to raise up all the way, and stay in that position.
is there a problem with that sequence that I’m missing ?
Z
Old Apr 5, 2026 | 10:38 PM
Jag#4's Avatar
Default Standard feature
Nope, the trunk/boot lid is just too darn heavy to go up by itself. As MVMonarch said above, it would take some pretty strong struts to open fully on its own. That lid weighs a ton. Both my 2001 and 1998 models worked as you describe regardless of the method used to open it.
As Jaguar might say, it's not a fault, it's a feature.
Renemarcel
Sep 14, 2024 04:51 PM
stevepaa
Jul 30, 2018 08:32 AM
Watchie
Jul 21, 2014 05:07 PM
wjd03
Jan 17, 2011 08:27 AM
