XK8 Convertible window trouble
Old Feb 29, 2008 | 12:49 PM
FactoryJaguarTech's Avatar
Default RE: XK8 Convertible window trouble
Replace the battery. When battery voltage falls below 10 volts while cranking, window memory is lost.
Old Feb 29, 2008 | 12:51 PM
Also, you will need to reprogramme windows after battery replacement.
Old Mar 1, 2008 | 04:58 PM
Is the window, dropping and coming back up when you release the handle, or is is dropping and staying dropped then drops further with each pull and release of handle?
If your voltage is dropping, I would say replace battery, that should take care of it.
If it drops and goes back up, probably door latch is bad. You will see on message center that is will not say drivers door open when it is.
The remote, you can find them on ebay alot. You can programme them yourself. Be wary of the ones on ebay though if used. There may be a reason why they are selling them.
There was an add on here for remotes at like 90% off.
http://www.originalkeyless.com/categ...?categoryId=29
Old Mar 3, 2008 | 08:21 PM
ibjags's Avatar
another happy camper
kj07xk
Dec 18, 2025 10:56 AM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
rsperle
Sep 12, 2015 08:37 AM
