XK8 door lock,key fob problem - RESOLVED
Old Jan 31, 2014 | 03:09 PM
cazthecat's Avatar
Default XK8 door lock,key fob problem - RESOLVED
Hello she's a 1997 xk8 rhd
Both of my key fobs worked locking and unlocking the doors, releasing the boot and putting on the headlights
I removed the drivers door card to grease the window runners ,which is now smooth in operation.
on opening the doors the windows drop, and go up when the doors are closed.
I can lock and unlock the doors and set the alarm with the key, when I select drive both doors also lock.
But now neither of my key fobs work (lock, unlock, boot or lights)
I have checked the block connector going to the door lock it seems ok.
I have checked the ignition switch ,the flap returns and the interior lights come on when the key is removed.
it seems something is preventing the fob talking to the car,
is there a micro switch in the lock
any suggestions would be appreciated
Last edited by GGG; Feb 9, 2014 at 07:03 AM. Reason: Add 'RESOLVED' to thread title
Old Feb 2, 2014 | 01:11 PM
Welcome to the forum cazthecat,
Simple things first. Have you tried reprogramming the fobs?
https://www.jaguarforums.com/forum/x...ers-faq-33580/
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member - Intro a MUST forum and post some information about yourself and your vehicle for all members to see.
In return you'll get proper welcome and some useful advice about posting to the forum.
Old Feb 6, 2014 | 02:16 PM
cazthecat's Avatar
Well ,went mad with the WD40 sprayed the block connecter , the door lock and the ignition lock (the little flap feels worn I think that this was the problem ). left it for a while so that the oil could do it's work.
success the spare fob now works , however the other fob still doesn't work.I have tried to re programme but the car won't "chirp".oh well I will just have to keep trying.
Don't you just love them
Old Feb 9, 2014 | 06:38 AM
cazthecat's Avatar
Smile
Result ,both fobs now working.
The solution was only turn key to Aux and flash the headlamps quickly No chirp but the red light flashed.
next job the wheel sensor,
Old Feb 9, 2014 | 07:05 AM
Good news.
I've added 'RESOLVED' to your thread title to help others searching for a solution to this issue in future.
......... next job - don't forget to post an Intro!
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
