xk8 drip strip seal
Old Apr 4, 2009 | 03:06 PM
hlgeorge's Avatar
According to my diagram there are two seals, an upper that is most of the seal and a lower that toward the front of the car.
Weatherstrip, Door Opening - Right - HJA5364AJ
Weatherstrip, Door Opening - Left- HJA5365AJ
Seal, Lower - left/right - HJA1650AD
Hope this is what you are looking for.
Old Apr 4, 2009 | 05:12 PM
JagtechOhio's Avatar
Greetings Jan,
I have a pair of good used upper window seals in stock. hlgeorge's part numbers are correct, and the Jaguar list price for each is $399...that means he can probably tell you where to get them for like $300. each. Mine are $200 for the pair, and I will include one of the lower seals at no charge if you need it. That part number was also correctly cited, and they list for $75.00. I only have one of those in stock, and it will fit either side of the car. The seals are coming from a 1997 coupe: the listing I referenced says that they are coupe only, and fit '97 through '06 XK8. Click on my screen name and send me a private message if you are interested.
Old Apr 4, 2009 | 08:58 PM
hlgeorge's Avatar
gregorjan,
If Jagtech can get you some good used ones, that's the best way to go! New ones are very expensive as Jagtech states!
Old May 22, 2021 | 09:40 AM
askforinfo's Avatar
Hi chaps, I found this guy on eBay https://www.ebay.co.uk/usr/rtay5993?ul_noapp=true I have fitted the top seal to my own car and they work perfectly, the cost was only £19. 00. He seems to be supplying lots more seals now so it's worth a look.
Bob
Old May 22, 2021 | 09:56 AM
askforinfo's Avatar
He supplies most seal for Jags shttps://www.ebay.co.uk/itm/Jaguar-XK8-R-Window-Waist-Trim-Rubber-Seal-Kit/174729260152
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
picard
Sep 19, 2015 08:13 PM
chatmanx
Sep 11, 2015 07:17 PM
Saturbo
Sep 8, 2015 07:35 PM
