XK8 electrical
Old Jul 30, 2015 | 01:16 AM
mikem's Avatar
Default XK8 electrical
Hi Guys, mine's 2003, weird fault message "check rear lights" then "cruise not available". Battery is absolutely fine. This is intermittent & happens sometimes well into journey, (lights are fine too when I checked) but once cruise control is engaged it does not fail , only when I turn cruise off or use brake. Often after this it will not engage again until later or else the fault message appears & will not go away until the system is reset by turning ign off then on again. any ideas pls. car is in Aus. cheers Mike
Old Jul 30, 2015 | 01:28 AM
Davidsw's Avatar
Could it be the brake pedal switch ?
Old Jul 30, 2015 | 02:39 AM
JagV8's Avatar
Just wondering how you know the battery's fine.
Even if it is, power from it may not be - i.e. bad wire/connector/etc
Old Jul 30, 2015 | 03:31 AM
jimbov8's Avatar
Both excellent suggestions above. I would first check the battery followed by the grounds.
The brake switch is a fiddle but well worth checking also.
Check the age of the battery also.
Old Jul 30, 2015 | 11:23 AM
krswen's Avatar
I'm having exactly the same issue with my 2004. Advice on this forum down below was that it is probably the dual switch that operates the brake lights and disconnects the cruise control (if it is on). $158 and a b**ch to change unless you are a small contortionist. I'm going to get my grandson to help me when I do mine.
Ken
Old Jul 30, 2015 | 05:59 PM
mikem's Avatar
Default xk8 electrical
many tks for info . I did trawl thru the posts & found the answer there as well. definitely the brake switch, I do regularly charge the battery which ,incidentally is new (although this is the third one after the bosch batteries were failing) I am a LAME (aircraft engineer) so I'm used to being a contortionist! I expect to find the connection faulty as this warning is but intermittent at present. cheers Mike
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
dstary
Sep 19, 2015 09:47 AM
frank regalado
Sep 16, 2015 06:15 AM
thefixer
Sep 11, 2015 09:17 PM
