Xk8 front grille
Old May 5, 2012 | 02:20 PM
Robert Scott Neilly's Avatar
I understand your reluctance to mess with the stock look, but I'm inclined to agree with Paul, the Rev, et al. I think the splitters and overriders are intended to evoke the look of the Series 1 E-Types, but they remind me of nothing quite so much as a kid with a honkin' big set of braces in his mouth. I went with the Mina mesh, and very much like the clean, uncluttered look. I would be happy to send you my stock parts, but the overriders were badly mangled by the original owner's attempts to park against a wall and keep his front plate attached.
The only downside so far is people who keep asking me if its a Maserati
Old May 6, 2012 | 06:17 AM
ollison's Avatar
Default Looking for originl Grille 1998 XK8
I'm Looking for the originl Grille 1998 XK8. The silver bar for sure, 573-746-0506 anytime.
Old May 6, 2012 | 04:58 PM
XKRacer's Avatar
I have dozens of these.....Literally
Old May 6, 2012 | 06:28 PM
millhouse_corfe's Avatar
Thank you for the reply. Are the original parts badly damaged or just used may I ask? I would really like them to be honest
cheers
Oliver
Old May 7, 2012 | 05:32 AM
Stan Clark's Avatar
Definately the stock Millhouse, your post #5 says it all.
Old May 7, 2012 | 06:50 AM
XKRacer's Avatar
When I get back to work on Tuesday I will sort a set out...... I am not a fan of the stock look, but I also dont like the flat mesh grilles or the convex type that sit proud of the opening.....
I prefer a convex mesh grille sat behind the opening giving the bumper a bit of depth, this is how I fit 95% of the XKs I modify...
Individuality is the key
Old May 7, 2012 | 08:18 AM
bassmania's Avatar
Before I purchased my XK8 the first thing that I planed to do when I got it was change the grille. After buying the car I decided to keep the stock grille because I reminded me of the lineage to the XKE.
Old May 8, 2012 | 05:03 PM
  #28
Thank you so much. Please let me know what I will owe you for the front grille, postage etc.
cheers
Oliver
Old May 9, 2012 | 02:41 AM
jamjax's Avatar
I happen to be in the other camp.
Never liked the 'rubber fangs' and prefer the clean lines of the mesh grills.
I have bought one from Boston JagXKR but will have it mounted reaccessed a couple of inches.
I agree that the XK8 series is one of the best 'retro' designs to come along and beautifully evokes the E Type series.
Maybe the problem with the 'rubber fangs' is that they aren't chrome like the original E Type series was but to my eye they clutter up the front end and are all but useless for protecting the front of the car unless someone backs into you perfectly parallel to the XK.
Wonder how the XK8 would look with no mesh and no fangs? Anyone done that?
Do you need the mesh to protect the gubbins behind it?
Here is some old eye candy for comparison.
https://www.google.com/search?q=XKE&...Fcf34QT-gaXZBg
Either way I really do prefer the plate below the cowl opening.
It shows off the beautiful lines of the car better.
You could always paint it on the bonnet like many early UK E Type owners did and the occasional XK8 but it always looked like a desecration of a work of art to me.
3G is that really your plate or did you Photoshop it?
Enjoy it with or without the mesh or the 'rubber fangs' they are marvelous no matter what.
cheers,
jj
Old May 9, 2012 | 02:58 AM
  #30
XKRacer's Avatar
I will do you both over riders and straker for £50 inclusive of delivery... I will sort you out a good set but you will have to let me know what type you would like.
Earlier items were more rounded later were flatter, take your pick
Old May 9, 2012 | 10:55 PM
  #31
H20boy's Avatar
Originally Posted by XKRacer
^^ Exactly as I thought, though I expected a bigger pile Maybe those were just the ones within arms reach.
Old May 9, 2012 | 11:16 PM
  #32
XKRacer's Avatar
Correct.......Those were the ones under the stairs, we have more upstairs in storage lol
Old Nov 2, 2012 | 05:44 AM
  #33
DaveC's Avatar
I like the looks of the mesh grill. Who sells the in the aftermarket?
Old Nov 2, 2012 | 07:27 AM
  #34
smoggyx100's Avatar
Originally Posted by GGG
Number plate size, colour and font must comply with regulations in the UK. Jaguar supply a black plastic mounting bracket and there is a little flexibility in exactly where it can be attached. Both these XK8's have the original standard grilles and use the same Jaguar mounting bracket:
Attachment 19140
My last 2001 XK8 on the right has the bracket below the intake grille whereas my current 2005 XK8 on the left has it fitted higher up covering part of the grille.
My preference is for the number to be below the grille. The 2005 looks dreadful!
I tried mounting the numberplate under the nose, but with UK speed bumps it did not work. So I used an adhesive one on the nose, moving the badge onto the bonnett (hood) like an e type.
Its passed 3 UK MOT's and been pulled by a speed camera, so no legal issues.
regards
Old Nov 12, 2014 | 04:30 PM
  #35
frankc's Avatar
My XKR is of 2003 origin and has a 3 part grill with the two fangs.
How hard is it to remove the fangs and install the new type grill?
Old Nov 12, 2014 | 05:31 PM
  #36
DevonDavid's Avatar
I don't know how it was achieved - done by a previous owner - but I quite like mine as I think it does have a connection with the original E Type which I like.
And yes - I know the horizontal bar is broken and needs doing properly
Old Nov 12, 2014 | 08:19 PM
  #37
5V1900's Avatar
Default reply from Brighton
hi I have a 1999 XK8 with a replacement mesh grille. Is there an easy way to restore it to the standard grille as it came out of the factory? This picture shows what i currently have
Unfortunately, the Brighton in which I reside is on the wrong side of the pond, in Ontario, Canada. Otherwise, I would pop around to do a swap, as I quite like the mesh grille.
Old Nov 12, 2014 | 09:16 PM
  #38
Jandreu's Avatar
Attachment 100506
I like this, exactly what I want. I have the three PC mash grill just need the chrome strip.
Old Nov 13, 2014 | 04:15 AM
  #39
XKRacer's Avatar
I have done similar... What I did was on a 2004 XK8, this has the bar set into the over riders from the front. The customer wanted a mesh grille but also wanted to retain the bar.... There is a thread on it some where....
Old Nov 13, 2014 | 09:59 AM
  #40
max224's Avatar
I liked the look of the E-type bar and emblem on DevonDavid's car, and it set me into looking for a way to have a similar look on mine, with or without the "fangs". I thought about purchasing a used E-type bar and modifying to fit, and also to make a center piece of some sort to hold the emblem for the same visual effect. How difficult is it to remove the bumpers and, what about the shock-absorbing mechanisms and brackets behind them? Do they also have to be removed? I also have a concern about the extent of front-end damage should I have even a minor accident. Given the cost of XK8 body parts, even a relatively minor accident could cost so much that the insurance company would likely total the car.
Nothing is easy.
