XK8 front shock bushing seal
Old Feb 7, 2016 | 08:33 PM
deelli's Avatar
Default XK8 front shock bushing seal
Wondered if there was a source for the seals that cover the front lower shock bushings...the bushings seem tight but the seals are bad???
Thx
Old Mar 13, 2016 | 09:14 AM
TexMurphy's Avatar
I guess you could try to replace them from a new bushing. I think I paid something like $15 a piece for the new bushing.
I think if that was all I had with a bad boot seal I would leave it alone, and wait for full swap.
I just changed both of mine in a complete rebuild of suspension.
I can tell you that once you start looking closer more will be found. The biggest one to examine is the shock top mount. Stick your phone camera up there and take a photo. You should have about 3/4 inch space where the foam is between the two plates. Mine was down to about 1/8 of an inch. This is a part that will effect geometry change to front suspension causing tire wear. I would also suggest a close examination of the upper wishbone bushings special attention to the rear one, as I think braking puts wear on them.
adenshillito
Mar 28, 2016 10:13 AM
Ungn
Mar 6, 2016 11:23 AM
sparkenzap
Feb 11, 2016 04:58 PM
Pilotman11
Feb 6, 2016 06:19 AM
