XK8 Gearbox Fault
Old Oct 25, 2016 | 07:41 PM
rsims's Avatar
Default P Codes
Hi All,
Moved post..
Old Jan 14, 2023 | 08:44 PM
pauljeeves's Avatar
Default Gearbox Fault
Hello,
My 2002 XKR is experiencing the common "Gear Box Fault / High Tempurature" issue, but only under specific circumstances. If the gear selector is left in the "D" position there are no issues whatsoever. However, if gears are manually selected (2,3,4, etc) then the fault mentioned above quickly appears and the car goes into "Limp" mode.
If I clear the fault with a scanner, disconnect the battery and wait a few minutes before reconnecting, I am able to restore the car to full capability. Then, provided that I only use, D, R, P or N, the car operates perfectly. The moment 2,3 4, etc is selected, the fault returns. The valve body has already been replaced and no MIL codes persist. I'm convinced that it's an a electrical/elecronic problem but don't know where else to look.
Anyone able to shed any light on this?
Old Aug 23, 2023 | 10:35 AM
Patersonguy's Avatar
2010 XK with 62K miles. Had a gearbox fault while driving in bumper to bumper at 100 degree heat; using the paddles. Fault came on; pulled over and turned of engine. Re-started and nothing further. Happened again two weeks later in similar conditions.
Same result.
Thoughts?
Old Aug 23, 2023 | 11:15 AM
Jon89's Avatar
^^ This is the 1996 to 2006 XK8 / XKR forum section. You should re-post in your appropriate forum section....
Old Aug 23, 2023 | 11:45 AM
Sorry about that; didn't notice the difference.
cissdm
May 3, 2016 06:02 AM
picard
Oct 12, 2015 11:56 AM
BSM
Mark V - X 420G
Sep 14, 2015 08:35 AM
rsperle
Sep 12, 2015 08:37 AM
pnwrs2000
Sep 3, 2015 11:55 AM
