XK8 gearbox top up problem
Old Jul 20, 2014 | 12:11 PM
creuse101's Avatar
Default XK8 gearbox top up problem
Hi.
I have a small leak from my XK8, and thought I would check the gearbox fluid level. I have previously done this on my xj8, but am confused to find that when I take out the filler plug, fluid pours out.
Correct me if Im wrong, but surely this is not right. Do I have to warm the box before taking out the plug?
I have the car raised level.
I can only find info on removing the top up plug after the box has been drained.
Cheers.
Paul
Last edited by creuse101; Jul 20, 2014 at 12:13 PM. Reason: additional information
Old Jul 20, 2014 | 12:30 PM
WhiteXKR's Avatar
The fluid must be at the correct temperature AND the engine must be running to get an accurate check.
RJ237's Avatar
The engine has to be running, circulating the fluid through the system. With the fluid at 30-50 deg C, the fluid will just trickle out with the engine running and transmission in neutral. Before checking, shift to D and R for a few seconds.
I measure the temp by sticking the sensor of a indoor/ outdoor thermometer in the fill port.
Old Jul 20, 2014 | 02:44 PM
creuse101's Avatar
Default gearbox
Thanks guys that answers that question. I have drained some out, and will refill accurately tomorrow.
Paul
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
