XK8 help! Lost Keys and Fob
Old Sep 19, 2012 | 11:35 AM
mike mitchell's Avatar
Default XK8 help! Lost Keys and Fob
some how i lost my key and fob. was told not to do this, by the guy i bought the car from. my question is.... am i at the mercy of the dealer on this ? (tear the house apart again, cuz i know this is gonna hurt if i dont find it). appreciate any tips.
Old Sep 19, 2012 | 11:55 AM
Friarshuck's Avatar
I have done a little research on this and, you can order a fob (ebay) and program it yourself.
The key, however, is a totally different story. Must be programmed by the dealer. My dealer wanted over $250 for the key and programming. I have heard of others getting a key from their dealers for as little as $100.
Guess my advice is call your dealer and see how much he charges. But, buy your fob off of ebay and program it yourself.
Good Luck
Darrell
Old Sep 19, 2012 | 01:28 PM
RaceDiagnostics's Avatar
I got a fob from ebay and the key from a mobile "Auto Key Cutting" franchise in the UK, for £70. If they do this in the UK it must be available in the US.
Old Sep 19, 2012 | 01:29 PM
+1 to Darrell's summary
Hope the vehicle is in a safe place?
Old Sep 19, 2012 | 04:38 PM
Arthur Dent's Avatar
I just went through the key replacement thing also. The locksmith actually was a lot more money than the dealer. Alpine in Fort Lauderdale wants 87 for each key and 140 to program. However, depends on the year of your car. 1997 to 1999 are cut keys from the dealer, no programming required, 2000 and up must be programmed. If you buy two keys they only charge once for the programming. Start the search, they must be somewhere.
Old Dec 30, 2020 | 05:54 AM
Karl S.'s Avatar
Banned
Default Lost key
I do know for a fact tou can take ur vin number into a local dealer and they cut ur fob or key right there and u use that to enter the car and then the computer gets hooked up under the dash board and chios the key and ur golden any lock smith should b able to do that however not the proper fob or proper key unless they are authorized by the jaguar company
Old Dec 30, 2020 | 09:34 AM
fmertz's Avatar
First off, you will need physical access. You will need to somehow have a tibbe 8-cut key made (easy, there are several options), but you will need either some code (dealer?) or a good quality picture of the old key. This will let you operate all the locks, including ignition, but not start the car (unless the car is US '97). The option of last resort is to somehow gain access to the trunk and CAREFULLY disassemble the lock. The specific sequence of angles for each disk/washer in the stack is the key "code". New trunk locks come with a one-pager description on how this works...
To start the car, you will need a crypto chip and pair it. Chips are cheap (megamos 13 for 2000 and before, megamos 48 for 2001 and later, check eBay). This chip would likely be embedded in a key bought from the dealer. Programming is a diagnostics port procedure. Some handheld devices claim to be able to do this (Foxwell NT510), or the full "dealer" SDD/IDS. This takes a few min. There is no add function, all keys have to be re-programmed at once.
For the fob, the cutoff is 2001 again. Before 2001, you are stuck with somewhat pricey used fobs on eBay I believe. For 2001 forward, they are "ford-compatible" and there are more and cheaper options. These can be programmed with no tools, it is just a sequence of steps (ignition on, flash the headlights, etc.). Check the stickies.
Best of luck, keep us posted.
99xk8guy
May 28, 2024 09:36 PM
peterg19
Feb 10, 2023 09:02 PM
SeanU
Sep 18, 2015 03:38 AM
jfitzoz
Sep 7, 2015 04:28 AM
My Pham
Sep 4, 2015 03:37 PM
