XK8 mirror interior
Old Sep 25, 2012 | 01:09 PM
calibrit's Avatar
Default XK8 mirror interior
OK my other problem,the interior mirror on my 1999 xk8 conv.The mirror has an oil line halfway down it,so top half is clear and bottom half is tinted.
How do I clear the "oil" out of it?or fill it to the top?is there an easy fix?
Old Sep 25, 2012 | 02:48 PM
K.Westra's Avatar
In short, the electrochromatic fluid that is responsible for the automatic dim feature is breaking down. The best option is to have Sybesma Electric rebuild yours with a new gel that won't break down. See this thread: https://www.jaguarforums.com/forum/x...acement-17719/ I would do this fairly quickly since the fluid can leak and eat away at whatever it lands on.
There is also an option to open the mirror and remove the fluid. However, this will mean your mirror will no longer dim, there are no guarantees you get it open and back together in a nice way, and if you try to do this and fail Sybesma will not take your mirror.
Old Sep 30, 2012 | 03:17 PM
steven300's Avatar
and might i add,the night time glare from cars behind you is annoying...steve.
Old Oct 1, 2012 | 01:58 AM
oyster's Avatar
Hi.
This is an early sign of the mirror will shortly start leaking, and as mentioned in another post the dripping fluid will destroy your interior. You can find used mirrors on ebay, but you will never know how long they will last. I found a new one, gel filled instead of fluid, but that was 175$. Easy to change following instructions in FAQ section. There are different versions depending on auto headlights, rainsensing wipers or not.
Old Oct 1, 2012 | 11:24 PM
Bigvettefreak's Avatar
I had a mirror that someone drained the fluid and it was horrible to drive at night and the auto light function did not work either.
The glare will trear your eyes out. I just bought another one from ebay and all is as it should be.
St.Regis
Oct 4, 2024 12:07 PM
kevinl
Oct 31, 2019 06:15 PM
Razor
Aug 28, 2019 08:34 PM
42Ajd
Dec 30, 2015 09:45 AM
John Fox
Sep 12, 2015 12:20 PM
