XK8 no crank resolved
Old Apr 3, 2024 | 08:01 PM
Cadman's Avatar
Default XK8 no crank resolved
Hi all, about 6 months ago I posted a problem of my 97 xk8 US car having the following complaints;
1 no crank
2 top doesn't work
3 no serial data to my scanner
4 message center saying electrical fault
with all that I asked for help and got alot of posts.
the problem was a defective ignition relay located in the trunk. When I checked for voltage at the ECM connector EM10 terminal 1, it was dead leading me to test all relays.
I could have diagnosed it months ago but I made the mistake of sending out my ECM for testing at a place called Automotive scientific. Do yourself a favor and never deal with this place!
thanks for reading and to all of you that responded to my cries for help.. .a HUGE thanks
Old Apr 4, 2024 | 12:06 AM
xalty's Avatar
japan made aj26 ecms are dropping like flies
even if it was misdiagnosed it’s a net benefit you got it remanned.
Old Apr 4, 2024 | 03:46 AM
Redjags's Avatar
Great news! As an aside, I bought a cheap 4 and 5 pin relay tester to check my relays. It runs a test of all pins and gives you a Go/NO Go status. Well worth having to do a very simple test and give yourself confidence in your diagnostic journey.
Sheree
Jun 28, 2022 06:20 AM
ToddRBritton
Feb 23, 2012 04:43 PM
jbenson911
May 18, 2010 01:28 AM
mr smith
Sep 29, 2009 04:52 PM
