XK8 No start after battery disconnect
Old Oct 16, 2022 | 04:15 PM
ace high's Avatar
Default XK8 No start after battery disconnect
2002 XK8 had dead battery. Took battery out and had it recharged and tested. Battery now fine. Re-Installed battery but engine will not crank. Dash lights on but no crank. Is there some kind of reset, since the battery was out of the car for a few days?
Sorry if this was ask before, but I could find a relevant thread.
Old Oct 16, 2022 | 06:17 PM
motorcarman's Avatar
Bad connection at 'mega-fuse' Protection module?
Try starting in Neutral?
DTC P1260?
Old Oct 16, 2022 | 06:39 PM
ace high's Avatar
Cannot shift out of PARK
Old Oct 17, 2022 | 09:05 AM
JayJagJay's Avatar
Are you saying that in no way shape or form can you get the shift lock to release? If that is the case, take something like a small phillips and poke around in the hole at the upper left corner of the of the shifter plate and gently pull on the shifter until it releases. Find neutral, put it back in park, try cycling the key - see what ya get.
Old Oct 17, 2022 | 10:43 AM
zray's Avatar
Are you stepping on the brake before attempting to move the shifter ? With the shifter in P you should be able to hear a solenoid -click- when you depress the brake pedal with the engine running, or at least with the ignition switch in the last position before the starter is engaged ( position 3 ??).
Z
PS do you have the owners manual set ? There is info in the manual about how to manually disengage the shifter lock. First the plastic blocking plug needs to be removed. You will need a Torx bit to do that, although a large blade screw driver might work.
Old Oct 17, 2022 | 12:59 PM
The TIBBE key is what is supposed to be used once the TORX plug has been removed.
Insert key shaft and move selector to N.
Remove key and insert into ignition lock barrel.
START ENGINE.
jgwjr
Jun 25, 2022 01:07 AM
cobratom
Dec 11, 2017 10:54 AM
jaguar51
Oct 30, 2017 07:47 PM
Petemcca
Jun 7, 2017 01:25 PM
SV8Predator
Apr 12, 2009 04:26 PM
