XK8 P1260 Security Input
Old Jul 25, 2017 | 10:42 AM
Cpt.NKT's Avatar
Default XK8 P1260 Security Input
Hello chaps. Have a question . I own an XK8 2000 with just 41000 km on her.
Driving the car I encounter an engine shutdown , and the additional Engine failsafe message etc... stopped the car , and trying to started again without luck. After 30 seconds it started again only to shut down after few miles and do the same thing. Then normal. Took it to the mechanic and he found a passenger door locking mechanism fail . As well the code P1260 . Security input . At the moment I'm waiting the part , but I don't know if this is the problem for the engine shutdown. Has to do something with the immobiliser as well, don't know. I've checked in other comments, battery is new , car just serviced and body throttle works perfect. Just to avoid answers about those problems . Looks like an electrical issue but... Any ideas or suggestions ? Many thanks to all !!!!
Old Jul 25, 2017 | 11:53 AM
jeremys's Avatar
thread I read seems to suggest a hard reset may fix issue if caused by ecu cant hurt to try
see procedure in diy facts sticky
Old Jul 25, 2017 | 01:07 PM
Cpt.NKT's Avatar
Jeremy thanks a lot. I'll give it a try. Will post anything I'll get from it. Have to replace the lock first. Any other suggestions more than welcome .
Old Jul 25, 2017 | 01:21 PM
motorcarman's Avatar
P1260 means that the key transponder is NOT RECOGNIZED.
Try another key.
bob
Old Jul 26, 2017 | 01:01 AM
Cpt.NKT's Avatar
Bob thanks a lot ! I'll try the green one. What about with the existing key? Do I have to reprogram something ? Or I need a replacement ?
Thank you in advance for your valuable infos !!!
