XK8 Play on rear wheels
Old Jul 25, 2015 | 08:20 AM
tonyforman's Avatar
Default XK8 Play on rear wheels
Hi, I have a rattle from the left rear, after jacking up I notice a certain amount of play on the rear wheel when rocked from top to bottom, not much just a millimetre or so, can't tell if this is wheel bearing or outer U joint on driveshaft. No movement when rocked left to right, so I assume the wheel bearing OK.
Then I jacked the right side up and it has the same movement!
My question is:- is this play normal for XK8's or are both outer cv joints in need
of replacement?
Is this a common problem?
Thanks. Tony.
Old Jul 25, 2015 | 09:17 AM
JonWat's Avatar
If you get someone else to do the rocking while you look from underneath you should be able to see where the play is. It may be at the differential as the drive shafts act as the upper suspension mountings or it may be in the universal joints which are under a lot of pressure because of this design.
Old Jul 25, 2015 | 09:36 AM
RJ237's Avatar
If it's only 1mm it's normal.
Old Jul 25, 2015 | 12:20 PM
tonyforman's Avatar
Thanks guys
Old Jul 25, 2015 | 07:23 PM
RJ237's Avatar
I have a rattle also, and I suspect the upper shock mount is going, similar to the front. But I'm not in a hurry and will wait for cooler weather.
Old Jul 27, 2015 | 08:22 PM
chrisgski's Avatar
Default rear hub bearing
i just had a left hand rear axle hub bearing replaced. left wheel had more play from 12 and 6 oclock movement than the right side. i also had a roaring noise associated with it. cost me $460 and it's all better now. noise started around 30 mph and got worst with speeds. it would sometimes quit with extreme right turns. grease your u joints.
Old Jul 27, 2015 | 08:28 PM
chrisgski's Avatar
Default location
just noticed your location, i had mine fixed at autowerks in fayetteville. if you go,tell Gina, chris sent ya.
99xk8guy
Sep 29, 2025 10:51 PM
prettydaim
Mar 28, 2021 07:47 AM
PMKimpton
Aug 3, 2019 08:22 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
innzane
Sep 2, 2015 10:08 AM
