Xk8 problem
Old Dec 1, 2014 | 08:13 AM
Shuey61's Avatar
Default Xk8 problem
Hi guys have 98 XK8 it has developed a bad vibration on acceleration and a lack of power this come and goes when it pleases any ideas please?
Old Dec 1, 2014 | 08:17 AM
WhiteXKR's Avatar
Welcome!
You should have the car checked for fault codes or purchase an inexpensive OBDII code reader. This car has extensive self-diagnostics and the first step is to see what the car thinks the problem is.
Also the best help will come from posting in the 96-'06 XK8 group on this forum.
Old Dec 1, 2014 | 08:38 AM
Shuey61's Avatar
Thanks will get checked with an OBD when I get home at the weekend
Old Dec 1, 2014 | 09:15 AM
Gus's Avatar
Gus
Post the codes not what you are told they mean.
Old Dec 1, 2014 | 03:48 PM
frankc's Avatar
Is there no member nearby who can read the codes for you??? Pop across to the UK and I will do them for you. Only cost perhaps a few beer tokens.
Old Dec 1, 2014 | 03:58 PM
cjd777's Avatar
Frankc, did they move Milton Keynes, last time I was there it was right outside Bedford???
Wayne
Old Dec 1, 2014 | 07:57 PM
RDMinor's Avatar
It sounds like a cylinder misfire due to a bad plug(s), possibly bad coil starting to go, especially when cold. It might go away once the engine gets thoroughly warmed up and not reappear for several days. Can also be bad circuit to coil which causes coil to not energize.
Did any lights in the dash come on or did you get any messages? Restricted Performance message usually limits RPM's to 3,000 max and below 2,000 it will be really rough as i9t cuts spark and fueling to the effected cylinder which causes an imbalance. Sometimes will smooth out at about 2100 or 65-70 mph.
Get someone to run a scan even if you get no lights or messages to see what code(s) if any is being thrown.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
