XK8/R dashboard
Old Jun 13, 2015 | 03:22 AM
samwhigham's Avatar
Default XK8/R dashboard
Hi everyone
I'm hoping you can help with a problem on my 1999 XKR.
quite simple the dashboard is not functioning. No lights and the buttons don't work. It's been having some work done including a new battery, so thought it could be related. My first thought was a fuse, but i'm a total novice.
Any advice / ideas or just good pointers would be appreciated.
sam
Old Jun 13, 2015 | 05:49 AM
test point's Avatar
Can you associate the failure with any battery or other electrical system change?
First thought is that such work may have caused the instrument cluster module to fail. You do not comment on a fuse check so, just in case, here is the fuse chart:
https://www.jaguarforums.com/forum/x...8-r-faq-33555/
Get that out of the way before we start making other wild guesses.
Old Jun 13, 2015 | 11:52 AM
samwhigham's Avatar
hi
So i had a little fiddle today. i can see that the fuse that keeps going is number 3 in box A (furthest to the front under bonnet). the handbook says this is 'security sounder, headlamp levelling motors, headlamp levelling switch, ignition +ve, centre console switchpack.'
Sam
Old Jun 13, 2015 | 04:28 PM
Originally Posted by samwhigham
...... It's been having some work done including a new battery, so thought it could be related. ......
Sam,
Listing all the work done prior to this fault should help get specific answers rather than general suggestions.
Old Jun 17, 2015 | 04:18 PM
samwhigham's Avatar
hi
i had a new battery put in, new disc brake, new exhausts and re-spray.
sam
JaguarLover101
48
Jun 12, 2023 10:28 AM
carl purchase
Oct 14, 2015 06:14 PM
Steve10
Sep 20, 2015 12:27 PM
Saturbo
Sep 8, 2015 07:35 PM
