Xk8 starting problems
Old Jun 26, 2017 | 07:24 PM
Jag_67's Avatar
Default Xk8 starting problems
Hi i have a 1997 jag xk8 that was starting ,running super well i parked for one week ,i try starting it,does not crank all that i get is a on the dash display a light
That indicates bonnete , has someone had a similar problem that can point me in the right direction thankyou in avance for your help it is greatly appreciated
Old Jun 26, 2017 | 10:39 PM
jeremys's Avatar
Do you have access to a code reader ,obd2, and if so what are the fault codes, is the battery fully charged ,12.5v at least prior to start,any other symptoms?
Old Jun 27, 2017 | 02:29 AM
Welcome to the forum Jag_67,
(I've deleted your identical post about this issue from the end of Thomas Eggleston's Intro thread.)
Battery has to be the first suspect - especially when you see odd messages appearing in the dash display.
Next favourite is connections in the High Power Protection Module (see item 5):
Cable connections are known to come loose or break at the lugs.
Old Jun 27, 2017 | 08:57 AM
Jag_67's Avatar
Hi and thankyou very much for your help i will try that , and will let you know.
