XK8 under carrige rattle
Old Nov 12, 2025 | 11:47 PM
reelthing's Avatar
Default XK8 under carrige rattle
I have had at times fairly loud other times soft rattle from the under
the car some place and was thinking body mount to sway bar bushings
after all this is a '98 and rubber does rot - but today i was messing around
in back checking air in the spare and such and looking at the sizable battery
and touched the tie down bracket it was loose and rattled - seems who ever
replaced it just had the torx bolts finger tight and they had worked loose a t25
fit well enough to tighten it down likely a t27 i'll pick up one of those - and man
she rolls quite - one small battle won
Old Nov 13, 2025 | 01:59 AM
brinny's Avatar
Always nice when you find an easy fix. Well done.
Old Nov 13, 2025 | 11:16 AM
SeismicGuy's Avatar
I have had what sounds like a rumbling from the rear for probably several years that is noticeable mainly if I am driving in a parking structure and the radio is off. Sort of sounds like it is coming from the rear bumper area so I found that I can jiggle the bumper cover a bit. I seem to recall someone else here also found something loose with the rear bumper and tightened it up somehow. Of course it could be something else entirely and I have just ignored it since it is not that noticeable during normal street driving not at all when the radio is on.
Old Nov 13, 2025 | 11:54 AM
bladerunner919's Avatar
The mounting brackets on the rear bumper are adjustable - at least in theory, as they are normally totally seized!
meirion1
Feb 7, 2025 07:47 AM
Rodkel
Oct 14, 2023 10:23 AM
roborob
Feb 17, 2017 09:51 AM
macdoesit
Jan 15, 2013 04:48 AM
dabsgm@yahoo.com
Apr 24, 2010 10:19 AM
