XK8 Victory Edition Microphone
Old Nov 26, 2024 | 02:29 AM
steve massey's Avatar
Default XK8 Victory Edition Microphone
I got the bluetooth to work in my car by ordering a new microphone.
I have a convertible and it's the beige bump next to the upper console.
The microphone clips into the base and the wiring runs into the upper console where it plugs in.
The replacement came with two small Phillips head screws.
But the old one has something different, two plastic things that hold the base to the header.
At first I though they were small Torx screws.
But instead they look like rivets, picture attached
[img alt="Old microphone, dangling from the base.
What are the two fasteners holding the base to the header?"]https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/xk8_ve_microphone_4a1f820f62e9840b6a254ece2107e55b 7627eebc.jpg[/img]
Old microphone, dangling from the base. What are the two fasteners holding the base to the header?
Seems a bit unfriendly.
Does anyone know what these fittings are and how to remove/replace.
I'd like to install the new microphone without damaging the header.
Thanks in advance for all the good advice here.
Old Nov 26, 2024 | 02:38 AM
I don't know why the picture didn't post.
Here's another try.
[img alt="XK8 VE microphone
What are fittings holding the base and how to replace?"]https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/xk8_ve_microphone_b4ea2ed7d785eee77132b020dda7b4b3 e5b2de17.jpg[/img]
XK8 VE microphone What are fittings holding the base and how to replace?
Old Nov 26, 2024 | 11:21 AM
michaelh's Avatar
The pic hasn't posted, but it sounds similar to the coupe's, which is held by a pair of pop rivets.
IIRC I removed them using a hand drill, as it's all a bit fragile. You can replace them with a couple of speed nuts and small stainless screws if you're putting the old fitting back.
Old Nov 26, 2024 | 03:57 PM
Many thanks Michael.
As I feared, but maybe I can drill them out.
I just don't want to cause any cosmetic damage to the header.
It would be so useful to have the phone work through the car's sound system and wiring.
Including the mute function when a call comes in.
Oh well, almost there, I'll think about it for a few days and update.
About the images, that's a nuisance - maybe there is a size limit?
thanks, Steve
Jrizzo003
Apr 20, 2024 10:34 AM
m2zoo4u
May 26, 2023 02:24 PM
gersola
Aug 1, 2019 06:01 AM
IreallywantaJag
Feb 24, 2015 01:00 PM
Clifsmith
Oct 14, 2013 08:55 AM
