Xk8 vvt rattle
Old Aug 12, 2017 | 04:11 AM
Umscheid's Avatar
Default Xk8 vvt rattle
1997 Jaguar XK 8 solenoid work when 12volt supply is put to them but do not worked when plugged to the proper connectors volt tester shows power going to both wire on connectors is this an ecu fault
Old Aug 12, 2017 | 06:49 PM
Don B's Avatar
Hi Umsheid,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X308 (XJ8 Sedans/Saloons) to the forum for the X100, which is the Jaguar factory project code for your 1997 XK8. Here you will find knowledgeable owners of similar cars.
I assume your car has an AJ26 engine, in which case I believe the VVT is just a two-stage design (rather than the later continuously-variable operation of the AJ27), so is it possible you are not observing the solenoids under the engine operating conditions during which they should operate?
What has prompted you to test the solenoids? Does your car have one or more diagnostic trouble codes flagged? If so, please post the exact codes here for the most helpful replies.
Please visit the New Members Area - Intro A Must and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old Aug 13, 2017 | 05:49 AM
michaelh's Avatar
OK, so the solenoid(s) appear(s) to be behaving.
The solenoids aren't energised when the motor is at rest or at low RPM, so 12V on both pins of the connector is to be expected in that scenario.
Can you expand on what you mean by 'rattle', and have any codes been thrown?
Mike
Old Aug 13, 2017 | 12:31 PM
joesoap's Avatar
Could this rattle be impending tensioner/chain calamity?
As michaelh asked why do you think its vvt related?
JimC64
Sep 22, 2025 02:52 PM
Phil Preece
Oct 17, 2016 01:41 AM
motorcarman
Oct 13, 2016 03:08 PM
97 Xk8 mayhem
Oct 8, 2016 01:27 AM
Jul 21, 2013 04:30 PM
