XK8/XKR Bluetooth - phone pairing
Old Feb 13, 2015 | 01:43 PM
HHI Life's Avatar
Looks like Jaguar has a new link for anyone looking for information on how to pair a Bluetooth device. Here is the link:
Vehicles - Jaguar
Old Feb 13, 2015 | 04:39 PM
JagNoir's Avatar
That link sounded promising. Alas, it doesn't seem to work. Not for me, anyway.
Peculiar.
*Correction*. It works, just didn't take my VIN. Still, the list of compatible phones seems rather outdated, e.g., iPhone 4 goes, but no 5, no 6, not even 4S. Oh well.
Old Feb 13, 2015 | 05:47 PM
ETexJag's Avatar
The website shows that I should have bluetooth compatibility
with my 06 XKR and my iphone 4,
but cant seem to connect -
the bluetooth app on my phone just stays at "searching",
but does not see the car.
Any hints?
Old Feb 13, 2015 | 05:53 PM
JagNoir's Avatar
Did you do the
Enter ##3#*# using the keypad and press the green Send/End icon ("Discover me" appears on the screen)
on the car screen?
Old Apr 12, 2015 | 04:47 PM
Canuck pump engineer's Avatar
Default Somewhat related to this thread...
Hello Graham and all,
I was reading this thread with interest. Some of the info it contains may relate to something I'm doing. I'm fitting a Garmin 2595 in place of the Jag SAT NAV in my 2003 XK8. Everything is going along swimmingly thus far except for one (hopefully final) piece of the puzzle. I want the entertainment system to mute when the Garmin audio plays. I have wires soldered to the Garmin's internal speaker exiting the case to connect to a circuit board designed to trigger a relay whenever it senses voltage at the speaker. I'm now wondering if I can use one of the pins in that yellow connector in the console to mute the entertainment system. Do you know if one of the pins is for 'radio muting'? If so, do you know which pin and how the mute function works? By that, I mean, will grounding that pin or applying 12V mute the radio? Would I need to add an in-line resistor before ground?
Here is a link to my posts to give you an idea of what I'm doing:
https://www.jaguarforums.com/forum/x...d-unit-118631/
I hope someone can help me with this. Thanks!
Old Apr 12, 2015 | 05:24 PM
Originally Posted by Canuck pump engineer
........ I'm now wondering if I can use one of the pins in that yellow connector in the console to mute the entertainment system. Do you know if one of the pins is for 'radio muting'? ........
Bill,
Here's the pinouts for the 2001 onwards 14-Way yellow connector:
Pin Number - 14 Way Connector.pdf
Telephone mute is Pin 6 (blue).
Old Apr 12, 2015 | 08:40 PM
Graham,
Brilliant! Thanks very much for your quick reply. Much appreciated. One detail... Is the radio mute function triggered by directly grounding pin #6? I just want to make sure prior to potentially doing any damage.
Old Mar 29, 2018 | 10:26 PM
  #28
giandanielxk8's Avatar
Interesting, that link HHI life shared seems to indicate my 03' has bluetooth (although I haven't found the microphone, what I have found are a few mesh grilles which I thought were microphones. (roof console and passenger b pillar)
I'll check to see if I can pair it, although, my iPhone 8 is probably not compatible?
Edit, sorry for the necropost.
Old Mar 30, 2018 | 02:43 AM
Bakewell's Avatar
The mesh grills in the b pillar and roof are occupancy sensors, not microphones...
Old Mar 30, 2018 | 06:52 AM
  #30
Jon89's Avatar
I believe that Bluetooth was introduced to the market in 2004, so I doubt if any vehicle built in 2003 came equipped with it....
Old May 7, 2021 | 04:30 PM
  #31
cgaechief's Avatar
Thank you.
Old May 7, 2021 | 04:38 PM
  #32
KRT's Avatar
KRT
I’ve just given up, tried everything and still wont pair with my IPhone
Old Aug 6, 2021 | 07:15 AM
  #33
rod9669's Avatar
Sorry to resurrect, my 2004 XKR has the corded phone installed, trying to find out if it has Bluetooth as well. Going through the PDF above, my display shows CARD to begin, with the phone unplugged, and as soon as I enter 1 in the codes the display goes blank. Tried the CTA trick, nothing
Any thoughts?
Edit to add, I've fitted an Android tablet to the dash temporarily to use as sat nav / media and it works ok through an FM transmitter, but wanted to connect it directly if possible
Old Nov 26, 2021 | 11:57 AM
  #34
brom1212's Avatar
Which aftermarket BT kit did you use?
Old Mar 2, 2022 | 09:59 AM
  #35
XKRED's Avatar
I recently had my 2001 XKR fitted with bluetooth by an outfit in North New Jersey. I'm very happy with the installation. I can recommend the shop if you're interested.
Old Mar 2, 2022 | 11:51 AM
  #36
Johnken's Avatar
Xkred, please tell us more. Does your steering wheel control allow you to skip up and down tracks? I'm from NJ too.
I've been an advocate for Discount Stereos' Bluetooth adapter for a while. Problem is, I put a different brand Bluetooth in my Toyota- it allows the track up down button on the steering wheel to work - didn't realize how bloody convenient that feature is. Want it on the Jag now too.
I look forward to your comments. Please tell us the brand too if you can.
John
Old Mar 2, 2022 | 05:07 PM
  #37
zray's Avatar
John
the Discount Stereo folks have an optional button that lets you select tracks up and down, etc. it comes with an adaptor to place it on the steering wheel. I was always knocking it off of there, so I relocated it to the cigarette lighter cap. Still pretty handy.
Z
Old Mar 2, 2022 | 09:49 PM
  #38
Johnken's Avatar
Thanks Z!!
John
Old Mar 3, 2022 | 07:50 AM
  #39
XKRED's Avatar
John
Hi John. Regrettably, my XKR doesn't have steering wheel controls to skip tracks. The volume controls work great thou.
Old Mar 3, 2022 | 08:52 AM
  #40
zray's Avatar
here is the remote button that works in conjunction with the Discount stereo Bluetooth adaptor.
https://www.discountcarstereo.com/BLU-WR.html
https://www.discountcarstereo.com/a2d-jag98.html?category_id=448
note: it changes tracks up/down, volume on the device up/down, and has the pause/start as well
you have to use your iPhone Bluetooth menu to activate it at the outset of each trip. Ie It doesn’t automatically activate like the base Discount Stereo system does. Alternatively you can repeatedly push one of its buttons and it will activate after the 3rd push. That’s the way it works on my 2002 XKR. That may differ model to model.
Z
PS So in essence, with the remote button you have two ways to change volume. The button will change volume on your iphone and you can still change the volume on the cars head unit with the Jaguar steering wheel control.
