XK8/XKR - OEM cross-compatible & Non-OEM interchangable Parts Thread
Old Sep 9, 2016 | 05:41 PM
  #41
MrsToadsWildRide's Avatar
My mechanic is talking about shocks and bushings. Any money saving suggestions?
Old Sep 9, 2016 | 06:28 PM
  #42
Veteran: Navy
try Welsh for upper shock mounts,
if you need bushings - XK's unlimited has OE type upper wishbone for $26ea or you could go with poly and order direct from Powerflex
Do you have the adaptive suspension or non? makes a difference in price
Old Sep 15, 2016 | 07:20 PM
  #43
RDMinor's Avatar
Default 4.0 Fuel injector to fuel rail O rings
The following are a perfect fit for the upper O rings for the fuel injectors on the '99 4.0 XK8 (probably XJ8 as well).
Fel-Pro ES 70599 $3.99 at your local Advance Auto but available pretty much anywhere I suppose.
Old Sep 24, 2016 | 09:17 PM
  #44
I saw on another thread that someone suggested taking the high pressure power steering hose to a hydraulic shop and having it fabricated. Does anyone know of a non eom replacement? 01 XK8.
Old Sep 25, 2016 | 01:17 PM
  #45
Goonybird7's Avatar
Default Fabircate Hose
Probably best to go with the fabrication idea. Most hydraulic shops are less expensive than you might think. Good Luck.
I'm looking at the same problem on my '97 XK8
Old Sep 25, 2016 | 02:36 PM
  #46
TexMurphy's Avatar
I have a 97, I would buy the high pressure as the new style route better and rebuild low pressure, there are some guys that have done the low side repairs themselves if you don't want to replace. I was lucky to find new in the box parts from a guy for cheap that sold prior to repairing for cheap and change both of mine. Let me know if you need any hints. Hardest part for me was r&r at pump of low pressure.
Old Sep 26, 2016 | 10:44 AM
  #47
MRomanik's Avatar
Veteran: Air Force
I replaced the high pressure line on my '97 two years ago. I used the new style hose. It was a PITA for a 67 yr old guy.
Old Sep 26, 2016 | 10:55 AM
  #48
TexMurphy's Avatar
To clarify what I found hard was the reservoir to pump hose, after 20 years it was so hard that it would not pull off after removing clamp. I had to reach in there and cut it off and that was a real bear, was same at reservoir. After all new hoses not a drop of oil, however I would suggest keeping an eye on quick connect.
Old Jan 14, 2017 | 03:08 PM
  #49
Atlastajag1's Avatar
Default Transmission oil for ZF6HP26
Not only did it cure the chirp on my 2005 tranny, but it costs a whole lot less and is used by Ford in those of its vehicles that use the same transmission: Mercon SP
Old Mar 9, 2017 | 07:39 PM
  #50
Hans944's Avatar
Default Perfect fit. Worked great!
Originally Posted by Canuck pump engineer
The side marker bulb socket from a 2010 Ford F-250 is an exact replacement for those in my 2003 XK8.
Ford Part Number: F8RZ13K371AA
Here is a link to a source I found for only $7.10 USD:
www.group1autoparts.com/ford/f-250-super-duty/f8rz13k371aa/2010-year/xl-trim/6-4l-v8-diesel-engine/electrical-cat/side-marker-lamps-scat/?part_name=socket-left
Worked great! Thanks again!!
Old Mar 23, 2017 | 06:46 PM
  #51
Canuck pump engineer's Avatar
Default Windscreen wiper refills
Had problems finding replacement wiper blades for my 2003 XK8 that my OEM airfoils could attach to, so I decided to simply replace the inserts (the only wear part). I found perfect fit inserts at O'Reilly's Auto Parts (here in the U.S.).
TRICO Part No. 45-205
Old Mar 23, 2017 | 07:15 PM
  #52
scardini1's Avatar
Good find, Bill! I haven't seen "inserts" in many years.
We had Airfoils? Didn't know that. I'd probably leave them off anyway - I like to see the bonnet in my view.
Old Mar 24, 2017 | 08:51 AM
  #53
rothwell's Avatar
I added the airfoils to mine. Jaguar Part #GJA8962CA
More pics of them in my working thread here
Old May 4, 2017 | 01:05 PM
  #54
larueb's Avatar
Default Coolant Reservoir
The Uro Parts #MJD440AB is a direct replace for the OEM expansion tank or coolant reservoir. It comes with the cap and level sensor. It is a plug and play.
Old May 17, 2017 | 12:27 PM
  #55
JT04Coupe's Avatar
Just found this thread Today. Great idea.
However I got lost somehow. I'm looking for a continuation of the springs and shocks question.
I'm looking for rear springs for my 2004 Coupe (non-adaptive). Does anyone know of any Ford Interchange possibilities? I know Ford loves to use the same parts across the board as possible.
Seems I can only buy either OEM springs (very pricey) or "lowering" springs (which I don't want either) here in the States. I have replaced the front springs with an after market pair that I bought from a parts store in the UK. Now the Coupe looks like it's trying to do a "wheely".
Let me know if you have any ideas.
Old May 17, 2017 | 12:51 PM
  #56
jgersman's Avatar
where is this located
Old May 17, 2017 | 01:06 PM
  #57
JT04Coupe's Avatar
If you are asking where this thread started, it's above on this page (as of today 5-17-17) and it started on 9-9-16.
Old May 31, 2017 | 03:34 PM
  #58
ghhb's Avatar
I am unable to find the Bosch Excel plus #41521, but there is a #41921, is this the correct number?
Old Jun 1, 2017 | 12:51 PM
  #59
larueb's Avatar
Yes, you are correct the #41921 is the right number. I pulled the original number from the receipt and it seems the clerk listed the wrong item.
Old Jun 9, 2017 | 12:14 PM
  #60
wlbusmcr's Avatar
Default Fuel Pump XK8
My 1999 XK 8 lost the fuel pump. The replacement that is a Ford Ranger pick up fuel pump as well as listed under Jag. Get them from Rock Auto. for ~$50.
