XKR 2001 no power to the CD multichanger in the boot.
Old Sep 1, 2019 | 02:27 PM
Soulfulfruit's Avatar
Default XKR 2001 no power to the CD multichanger in the boot.
Hi All,
Have owned the 2001 XKR for three years. Has issues with the CD player intermittently working in first 6 months. Got a 2nd hand replacement unit but appears to be no power coming through. Or the CD button on the Head unit in the dashboard doesn’t work.
Any suggestions?
Are there any hidden inline fuses I could check?
Old Sep 1, 2019 | 09:52 PM
Johnken's Avatar
As I recall, connecting the cord, therefore the power, will produce noise from the changer as it cycles and reads cds.
Have you tried this with both units?
This could eliminate no power as root cause.
John
Old Sep 2, 2019 | 02:22 AM
Hi John,
Thanks for quick reply. I have had both units in and out a few times, plugged and unplugged them with ignition on and off to check but they make no sound 😟
Thanks Vince
Old Sep 2, 2019 | 09:19 AM
Johnken's Avatar
Then I'd check for voltage (12v) on the male side of the connection in the trunk.
We do have a pinout diagram on the site here. As I recall Lady Penelope posted it. Just remembered I posted a copy of it last week or 2.
John
Old Sep 2, 2019 | 09:46 AM
Thanks John,
I look it up and do some testing 👍
Vince
Old Sep 2, 2019 | 10:08 AM
DavidYau's Avatar
Default No separate fuse for CD player
Do you have the premium sound system with an Amp above the CD player.
A fellow forum member, Ryan B, has all sorts of problems with his music system.
As far as I know there’s no separate fuse for the CD changer but I recollect it’s powered from the radio deck unit. So if the radio works, it’s a bad connection from the radio to the CD changer.
Not it sure what the pin layout is in the DIN socket but try search function for it.
Old Sep 2, 2019 | 10:32 AM
Default No Amp above the CD unit
Radio works well, elec arial works, cassette player also works well. Agreed sounds like a connection issue from front to back. Put a new earth strap on from a new battery to chassis. So sure that is good. Old built in telephone had been removed before I owned it. Haven’t had the dash or centre consul out yet.
Old Sep 2, 2019 | 10:55 AM
Johnken's Avatar
Here's the pinout. Find voltage = defective unit. No volts focus the hunt for failure point.
https://www.jaguarforums.com/forum/x...um-one-195209/
John
mrjimbo
Mar 3, 2015 03:28 PM
lidesign
General Tech Help
Apr 12, 2013 02:18 PM
Jag#4
Audio/Visual Electronics
Aug 14, 2012 09:38 PM
jol
Feb 22, 2012 08:18 PM
Michael Jeansonne
Jun 23, 2011 08:17 AM
