XKR 99' Headgasket/front suspension rebuild
Old Apr 3, 2016 | 12:46 PM
Jagman28's Avatar
I will use the mls headgaskets and not the standard ones. Hope it will work out
Old Apr 4, 2016 | 07:27 AM
XJR-99's Avatar
The only reasonable decision. That's why Jaguar changed from composite gasgets to MLS ones starting from MY 2001.
Old Apr 12, 2016 | 09:32 PM
Jagman28's Avatar
Final torque on the rebuild heads 😅
Adjusting the valves is a big job, 8 done 24 to go
Old Jun 7, 2016 | 05:10 PM
Jagman28's Avatar
Big job adjusting the valve clearance ! I got 14 perfect with the shims i had, the others i had to order... and they are expensive :O
Stainless steal exhaust with the custom downpipes
The shims, i used a facom digital caliper and a feeler gauge to adjust the valves .20 inlet en .25 exhaust
Home made locking tool
New distribution set from the dealer
Almost ready to start, a lot of cables to reconnect ! Insert oil and cooling fluid
Only the air inlet left cant wait
Old Sep 17, 2017 | 03:18 PM
Ekskaar's Avatar
hi all,
I am quite new here (not yet found a introduction tread) but am looking for info on just the job in tread subject.
I plan on putting the heqds back on asap, but 2 valves need adjustment.
Haven't succeeded to get the shim from the cups yet..
Looking at current old tread, that looks stopped before succesfull job finishing,...maybe there are things to think of, that topic starter did not share in 2013, or was not aware about?
Grtz from the Lowlands.. (The Dutch ones;-))
Old Sep 17, 2017 | 03:51 PM
dsnyder586's Avatar
The correct procedure is to use a compressor and blow air between the shim and the bucket. Using a magnet is a no-no by the way.
Old Sep 18, 2017 | 02:42 PM
Ekskaar's Avatar
Thanks, that worked! (still took a while but it works well)
Now up to the nice task of putting the engine back together!
Philly Single
Mar 25, 2016 10:49 PM
SD96XJ6L
Mar 15, 2016 10:23 AM
carmelnsilk
Mar 13, 2016 08:03 PM
XKR2000
Mar 13, 2016 06:52 PM
Jandreu
Mar 12, 2016 05:22 PM
