xkr auto box fault
Guest
Posts: n/a
hi i hope someine can help
i have just purchaced a xkr 2003 model ( 6 days ago )
it seems to have an intermittant fault in the gear box, on 5 occations when setting off the box has stayed in a low gear and the engine revs will go up to 4 or 5 k with no gear change , not pulling away quickly and steady acceleration
if i come to a stop then set off again its fine
it did it 4 time yesterday so i am now concered
please help
please help
Assuming you have checked that the seller is not liable, I would first check for fault codes with a professional reader, and also have the fluid level checked.
The 6HP26 detects cornering by comparing the speed of the front wheels, if it detects a difference; the gearbox will not up shift so could be your problem. Check tires for correct circumvent (pressure/thread depth), or better check it with a professional obdii tool, that can read the wheel speed values, the variance should be smaller than 1 km/h.
