XKR Bank 1 heated sensor Help please.
Old Nov 3, 2009 | 08:09 PM
mbalce's Avatar
If it was me, I would ask them for the part number of the sensor and fitting they are planning on replacing and google them or plug them into ebay. Usually the dealer is very forthcoming with that info. Are you planning on installing yourself then? Always interested in how far a somewhat competent amateur can take these things....
Old Nov 3, 2009 | 08:17 PM
test point's Avatar
Looking up the online prices of OEM (Bosch) 4-wire, heated, upstream oxygen sensors for the XKR they are in the $120 range. DENSO OEM is almost $300. Generic versions as low as $100.
Somehow I cannot understand the difference in the $50 (Bosch) OEM 4-wire, upstream O2 sensor I need for my Lincoln.
I would suspect the difference is the connector and length of the wires.
Sounds like profit to me.
Old Nov 4, 2009 | 05:15 AM
Brian2000XKR's Avatar
I had the same problem a few months ago. After a massive Internet search, I ended up buying 2 at Amazon.com for $120.00 including shipping. These were Bosch O2 Sensors with plugs, not the Universal ones that you have to re-wire somewhat. I have a great independent mechanic who installed them reasonably. He did say that they were a bitch to replace as the old ones were so hard to get out.
Good luck!
Brian
Old Nov 4, 2009 | 09:28 AM
oldmots's Avatar
You might try www.oxygensensors.com. I have used them and they have OEM quality parts at low prices, and very fast shipping.
Steviedee1st
Nov 28, 2023 06:32 PM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
Sep 6, 2015 06:51 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
