Xkr engine noise
Old Jan 23, 2025 | 02:59 PM
orangegoose's Avatar
Default Xkr engine noise
So I have a 50000 mile 2000 XKR with an engine noise staring up cold.
It sounds exactly like a hot engine cooling down, metallic ringing like a light hammer on metal.
It occurs every few seconds for a bit while warming up. It seem to emanate from upper engine like intake plenum.
If I drive it down the driveway and stop for a few seconds, it never occurs, even when still not warmed up.
Tensioners were done, this is not a chain rattle. Almost like a church bell every few seconds. It has developed a belt squeal until warmed up.
A friend suggested cracked exhaust manifolds... which I've never heard of on a Jag.
Otherwise the engine is super smooth and quiet.
Any suggestions?
Old Jan 23, 2025 | 09:15 PM
zray's Avatar
Exhaust heat shields cracked and rattling
Z
Old Jan 24, 2025 | 03:08 AM
bladerunner919's Avatar
When a cat goes bad and starts to break up it sounds exactly as you describe.
Old Jan 24, 2025 | 08:04 PM
Red's Avatar
Red
I don’t have an R but isn’t there a bearing on the front of the supercharger that can get noisy? And something else at the back that can make a different noise that I am forgetting the specifics of at the moment?
Old Jan 24, 2025 | 10:40 PM
brinny's Avatar
I thought cat.
Old Jan 25, 2025 | 02:28 AM
Pistnbroke's Avatar
Wrong forum its an XJ6
Old Jan 25, 2025 | 05:12 AM
The OP says it's a 2000 XKR?
fredwashere412
Feb 24, 2024 12:12 PM
Peter Ucinski
Aug 11, 2021 09:56 AM
AlexJag
May 26, 2021 08:49 PM
tanngo
Aug 9, 2010 11:02 PM
