XKR idle surge
Old Jul 28, 2015 | 08:35 AM
stevee D's Avatar
Default XKR idle surge
I have finally got most of the bugs out of my 2001 XKR except for the idle. It runs fine off idle, but Idles like a 350 chevy with a 3/4 cam. It lopes enough to make the car rock at stop lights. I have checked all over for air/ vacuum leaks and checked the mass air sensor. I cleaned the throttle body, but it still the same thing. I have not checked the crank position sensor yet. Is there a programming setting that needs to be done or is this a mechanical problem I have missed? thanks for reading this steve
Old Jul 28, 2015 | 09:54 AM
WhiteXKR's Avatar
Any OBDII codes?
Have the chain tensioners been upgraded? It is possible one of the chains slipped a tooth.
Old Jul 28, 2015 | 12:05 PM
stetson1's Avatar
here's a forum page where they got it right, good luck:
https://www.jaguarforums.com/forum/x...e-body-123306/
frank in fl
Old Jul 28, 2015 | 03:07 PM
stevee D's Avatar
OK, guys, I found a vacuum leak between the supercharger and the inter-cooler. redid the connection and the car smoothed out. I was under the impression that area was a positive pressure, but it really is negative pressure until the motor comes off idle. Thanks for your input. It is wonderful to have this forum with all the great people. steve
Old Jul 28, 2015 | 06:26 PM
stetson1's Avatar
Steve, here's the one you want, scroll to bottom of page:
https://www.jaguarforums.com/forum/x...igh-rpm-84948/
again, GL,
frank in fl
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
hhv00586
Sep 18, 2015 08:59 AM
explorer364
Sep 14, 2015 07:43 PM
explorer364
Sep 11, 2015 05:44 PM
raulan
Sep 10, 2015 12:43 PM
