XKR - lights out when I turn the (left) indicator
Old Sep 17, 2015 | 08:38 AM
Ekki's Avatar
Default XKR - lights out when I turn the (left) indicator
Hi folks,
weird problem here with my 2001 XKR: sometimes when I tip the left turn signal the low beam and the interior lights (i.e.: all lights) go out for a fraction of a second. Interestingly this only seems to happen when the light switch is in 'auto'-mode.
This doesn't happen all the time, so I suspect some kind of (occasional) short circuit.
Okay...workaround would be either not to use the 'auto-light' or never turn left again when it's dark. ;-)
OTOH I would be interested if the electronic gurus here might have an idea about this (admittedly) very special problem.
Thanks!
Ekki
Old Sep 21, 2015 | 11:55 AM
AiJhae's Avatar
Originally Posted by Ekki
Hi folks,
Thanks!
Ekki
I would start by looking for an earth fault, either near the switch, near the relay or near the bulb. You can test by making a wire with crocodile clips and shorting the earth to the battery, if the fault goes then you know which earth is not contacting the body.
Old Sep 21, 2015 | 12:09 PM
WhiteXKR's Avatar
The turn signal stalk has several soldered wires, which sometimes break off. They can cause both opens and shorts. It is worth inspecting, and they can be re-soldered if necessary.
BrentGardner
29
Dec 16, 2024 12:13 AM
tberry6686
Sep 20, 2015 03:22 PM
plmmd
Aug 31, 2015 10:07 AM
kesslari
Aug 31, 2015 04:53 AM
