xkr trans question
Old Jun 5, 2015 | 11:15 AM
stevee D's Avatar
Default xkr trans question
OK After I did the 4.0 to 4.2 swap and found a couple of vacuum leaks, I took the car out for a short test drive. The motor idles like it has a big cam and puts out tons of power when you step on it. The problem I have is it only drives in what I think is 2nd gear. Goes in park, reverse and drive and will down shift if you stomp on it, but will not shift up to higher gears. I probably have not connected something right but can't figure out what it would be. I did not pull the trans when I did the swap. Any info to look in the right direction would be great. thanks steve
Old Jun 6, 2015 | 08:50 AM
ccfulton's Avatar
I assume that the trans was working properly before the swap? Shifting through all the gears, etc.
Maybe you could try a hard reset now that your vacuum leak and all that is fixed. Is the battery good and strong? These cars are prone to electrical misbehavior.
Do the sport button and J shifter side of the lever work? Thinking here is that maybe you have a slight adjustment problem on the shifter cable.
I don't have a 5spd but as I recall putting it in sport causes the car to start in gear 1. Does it up shift 1-2 in that case and then not to 3?
FrickenJag
Jun 16, 2025 02:15 PM
vsol
Aug 29, 2018 09:46 PM
Skeeter
Sep 17, 2015 08:15 PM
skadmiri1
Sep 9, 2015 11:27 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
