XKR water spilled in trunk, power out
Old Oct 11, 2015 | 09:11 PM
mikessj's Avatar
Default XKR water spilled in trunk, power out
I need help. I coach football and on the way to a game our cooler full of water dumped in the trunk. Now the convertible top has now power, the reverse sensor has no power and the power trunk latch has no power.
I checked the fuses in the trunk and they all look fine. Several gallons of water shorted something out.
Any ideas?
Mike
Old Oct 11, 2015 | 10:33 PM
WhiteXKR's Avatar
The Security Control module (SCM) is located directly below the trunk fusebox and almost certainly got wet.
It is directly involved in control of both the trunk latch and top operation.
To get access, disconnect the battery. There are 2 or 3 bolts which hold the rear fusebox in place...remove these, as well as several wire harness retainers. Then, flip the fusebox so you can unsnap the SCM module from the plastic latches which retain it to the underside of the fusebox. Unplug the SCM connectors. Now, with the SCM removed, snap open the housing. If is is just wet. it needs to be thoroughly dried, then it can be retried. You may or may not get lucky and have it function again. If you see corrosion, or burn marks, it probably will more than likely need to be replaced
The reverse sensors and or the reverse control module may also be water logged. The module is usually mounted in or near the bottom of the trunk at the rear of the car.
BTW, circuit boards can be dried with a hair dryer, then it is a good idea to immerse it in uncooked rice (a natural desiccant) for at least a day to suck out any hidden moisture.
Old Oct 13, 2015 | 12:43 PM
Johnken's Avatar
whitexkr,
Steve, you know more about electronics than I do. When would you first douse flooded electronics with distilled water, after power disconnected of course and before the Rice? Is that more likely to help with micro electronics where tap water's disolved minerals can more easily bridge conductors?
Not trying to correct you, just thinking out loud and providing the logic for my question for others to understand why I'm asking. Love to hear what you think when you get to it. Thanks. John
Old Oct 13, 2015 | 12:50 PM
WhiteXKR's Avatar
Originally Posted by Johnken
whitexkr,
John, you are absolutely right, an initial rinse with distilled water, (or isopropyl alcohol) after removal and prior to drying is a beneficial extra precaution.
Old Oct 13, 2015 | 04:01 PM
Johnken's Avatar
Thanks Steve,
I love the isopropyl alcohol idea.
Unhingd
Aug 16, 2025 01:06 PM
philwarner
Jul 4, 2017 08:49 AM
mjm3457
Oct 17, 2015 02:18 PM
The PuurFect Fast Cat
Oct 9, 2015 03:48 PM
77hdfx
Oct 6, 2015 09:27 PM
