XKR won't turn off despite removing the key?
Old Sep 28, 2015 | 04:23 PM
aode06's Avatar
Originally Posted by Flyboy7
Just an update. Since my visit to the Jaguar dealership last year, they did indeed find an issue by the throttle body with a wire that was frayed. The other issue that was found was with the main wire harness at the very front of the engine bay zip tied to the cooling fans. This clip had broken off and was rubbing in the front, allowing part of the insulation to wear off and shorting out randomly. The tech at the dealership fixed the wires and I haven't had this condition happen since.
Though I didn't see the actual wires that were frayed, the tech told me that he really had to do some examining with a really good flashlight before he was able to see it.
the driver side ignition relay in fuse box, needs to be changed andbthe bcm capacitors treated. My car still does this and it even has the techs in laugh ter,asbthey call my car possessed.
Old Sep 29, 2015 | 08:17 PM
markaltobelli2002's Avatar
aode06 wrote: "the driver side ignition relay in fuse box needs to be changed and the bcm capacitors treated."
Is there a relay map for the XK8 that shows which relay in which driver side relay box is the ignition relay? Is it the center box, center row, furthest toward passenger side?
Is there some information about treating BCM capacitors?
Thanks!
Old Sep 30, 2015 | 07:49 AM
aode06's Avatar
Thanks!
start pulling the relays by the driver side door, when your car shuts off, that's the relay you are after, this worked for me.
Old Oct 3, 2015 | 07:31 AM
aode06's Avatar
The bcm is behind the glove box, it can be sent out to any ecm repair shop on ebay to replace any bad capacitors for cheap.Also when the car is stuck on bang your driver and passenger seats to see if the cluster light s flicker, if so check wires and module below the seats by removing the seats.
Old Oct 4, 2015 | 11:54 AM
Default Ignition relay location and BCM capacitors
Thanks for the tips.
I still hope to find a relay map someday. The first time it wouldn't shut off, I pulled fuses and relays until something worked, which was the fuel pump relay. There are at least a half dozen boxes with relays on this car, and I started in the wrong box. I was pulling the ECM fuse to shut it off, but I was warned that might harm the ECM, so now I'm disconnecting the battery ground to kill it. Afterwards it will either restart immediately or not for hours. Hopefully the problem is simply a sluggish or flaky relay.
Old Oct 4, 2015 | 02:13 PM
Gus's Avatar
Gus
This oneline for a 2000 XK8/R has the relays marked on it. I would suggest swapping the relays first and if it shuts down.
Link to oneline http://www.jagrepair.com/images/Auto.../jagxk2000.pdf
Old Nov 3, 2015 | 07:53 AM
aode06's Avatar
Found the problem,
the ac pressure sensor wire harness rubbed on the crankshaft pulley, causing several wires to short to ground and also cut a few.
You cant see it that good at top, but jack up the car and directly in the center of car at crank pulley, you will see what Im talking about.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
Sprayall
Sep 3, 2015 07:49 PM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
