ZFHp24 transmission flush
Old Aug 25, 2018 | 10:13 PM
Ltd's Avatar
Ltd
Default ZFHp24 transmission flush
Just wondering if anyone has tried flush their tranny thru the cooler lines at the radiator?
I have the blue jug of Jag spec fluid. Got it free at a yard sale
Old Aug 26, 2018 | 09:21 AM
David F.'s Avatar
Default I have done it
When I replaced my radiator I decided to also flush the transmission. I drained the transmission and did a "EXACT" measurement on the amount of fluid that came out. I removed the top radiator line and refilled the transmission with the same amount of fluid. You fill the transmission via the "line" not going through the radiator. Make sure to replace the o ring to avoid leakage. When you drain the transmission you should get around 3 quarts of fluid.
Old Aug 27, 2018 | 04:43 AM
Ltd's Avatar
Ltd
Default Thanks
Filling thru the top line sounds very doable. Did you pump the fluid in? Or just gravity flow, like a funnel and plastic tubing? Also, where did you source the "O" ring?
Ltd
Old Aug 27, 2018 | 08:45 AM
David F.'s Avatar
Yep, gravity feed is enough it just requires a little patience. Remember to use the top line back to the transmission, do not go through the radiator. I get my O rings from NAPA but some hardware stores also have a good selection. Another issue is to make sure the fluid you are using meets specification LT 71141, I used Castrol.
The big issue is the problem of having the correct amount of fluid in the transmission. Unfortunately the only method of doing that is rather involved and requires having the car lifted and checking while the car is running and up to operating temperature. Pretty dangerous unless you have a way to safely lift the car , For me that was a job for a good shop familiar with ZF transmissions.
good luck
Tom Baker
Nov 3, 2017 06:56 PM
AlbBolivar
Nov 23, 2013 11:44 PM
hawaiianjag
Aug 31, 2010 07:44 AM
Trooperbsb
May 19, 2009 10:01 PM
2000blackxkr
Apr 17, 2009 05:41 PM
