Eurotoys porting?
Old 12-28-2010, 07:47 PM
Michael Star's Avatar
Default Eurotoys porting?
http://eurotoysltd.com/catalog/produ...oducts_id=1181
They are saying 45-50hp with porting and the 1.5 pulley, and 55+ with the 2.5/3 pulley.
Old 12-28-2010, 08:20 PM
Riski's Avatar
It is about right.....but I want a dyno tune....they are right down the road from me....
Old 12-29-2010, 01:40 PM
Phil_Deeznuutz's Avatar
I was looking at their package(s), and I saw the $575 'supercharger remanufacture' upgrade. Does anyone happen to know in what situations that would be necessary/preferable? My supercharger still barely has 20,000 miles of use, so I would think it is not beneficial to remanufacture it...but, on the other hand, it is almost 8 years old. Thoughts?
Old 12-29-2010, 02:18 PM
Riski's Avatar
I want to say it was for units with 75k miles or something like that....but you should be fine
Old 12-29-2010, 03:24 PM
bfsgross's Avatar
Though your STR is 8 y.0, with 20k on the clock it's still a virgin. My 03 STR has 104k. The blower never been touched except a 1.5 pulley...runs like a top.
Old 12-29-2010, 04:03 PM
Riski's Avatar
I think I am gonna have to go over to the shop and check them out.....maybe after the first and I will report back for you folks.....
bfsgross (12-29-2010)
Old 12-29-2010, 04:51 PM
From Eurotoys site they said that it needs to be done if you only have 40-50k miles on it. That seems crazy to me.
Old 12-29-2010, 05:14 PM
Riski's Avatar
When you take the blower off and there is a lot of play in the within the snout then yea.....but most of them are not needed and they get inspected upon ported....so if they are bad, they will let you know....So I would not pay for the rebuild since it will be "rebuilt" when put back together......and sent back to you to be installed
Old 12-29-2010, 05:22 PM
bfsgross's Avatar
X2 on that. Compared to earlier generations, our fourth generation Eaton blowers come with stout bearings and seals. I'm betting on a preventative rebuild at 100k miles minimum. I'm leaning towards sending my blower out this winter for a port/polish, and a 3 lb pulley. While there, a shop can decide wether to perform a rebuild.
Old 12-29-2010, 05:39 PM
Riski's Avatar
Stop debating on doing the pulley and do it already so you can preach about that too
Old 12-29-2010, 09:18 PM
bfsgross's Avatar
You're on bi%$h! And to make it more interesting...I'm gunna make a special trip up to the Windy City and we're gunno go for pinks... I might sell yer STR back to ya if ya shed some tears...LOL!
Old 12-30-2010, 08:51 AM
Riski's Avatar
If you think that could actually happen come on.....I have a white bottle that might make sure that dont happen haha.....but I am down for a road trip to for a damn dyno tune of this POS computer
Old 12-30-2010, 10:27 AM
Are we any closer to finding a dynotune spot? I haven't been paying attn lately, hoping I missed something
Old 12-30-2010, 10:40 AM
Enthusiast's Avatar
In the new year I am looking to port, go with the 3 and perhaps the lower crank.....take a look at their setup and let us know.
Would be much appreciated and nicey nice!
Old 12-30-2010, 10:52 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
What's POS about it? avos seems pretty happy with it so just wondering why you're not?
Old 12-30-2010, 10:59 AM
Riski's Avatar
just saying POS cause no one here can dyno tune it.....AVOS bring your computer skills here to the states.....I have a room you can stay in w/ plenty of good food!!
Old 12-30-2010, 12:00 PM
JagV8's Avatar
I guess I don't understand why you think it needs tuning. What's it doing wrong?
Old 12-30-2010, 03:12 PM
Riski's Avatar
nothing, I want the extra power the car has to offer....There is always more power to be had dyno tuning over a stock ECU....The tune within the Jaguar is a very safe tune.....I want the limits!
Old 12-30-2010, 03:43 PM
JagV8's Avatar
Have you run out of other mods to do?
Old 12-30-2010, 03:55 PM
uropnm6's Avatar
In my own experience Dyno tuning is only for HP. Not drivability I had my euro M6 turbo tuned on a Dyno but when it came to just driving around it was not very driver friendly, I ended getting a friend and basically street tuning the car whilst driving much more appealing, I can do this because I installed a TEC3r standalone ECU ,this was done because Dinan who installed the original turbo set up back in 1987 did not want help when I had some electronic issues with the car, all they said was send it back to us and we will try and fix it. Only trouble is that I live NY they are in CA so it was easier and probably cheaper for me to install this system it runs a wide band O2 sensor so you can read your air fuel ratio. You can adjust every thing with this Timing - injector pulse - pulse width - timing advance - boost activated retard - engine rpm limit - soft limit shutting down every other spark or every other cylinder spark so you don't over rev or lean out the engine. I have had this on my bmw for around 8 years and no problems, I am sure that there is probaly other systems out there now maybe better may be not? I would not have any concerns about installing the TEC3r in another car, the situation I had is that this system uses Gm sensors so I had to install all new sensors that came with the kit. You tune the car off of your lap top which has like a virtual dash board showing everything you need to know. It also has a recall setting where you could do a run then play all the sensors and a/f ratio, exhaust temp, inlet temp, max boost etc, All in all a pretty nice set up.
I think now that some of these system do a plug and play set up where you would unplug the ECU and plug the TEC3r into the stock wiring. But probably not for the Jag although I have not checked but his could be a possibility for those who want to MAX out the power. Paul
Quick Reply: Eurotoys porting?
