'02 X-Type Broken Sway Mount Fixable?
Old 04-19-2014, 12:08 PM
bkmadison's Avatar
Question '02 X-Type Broken Sway Mount Fixable?
Hi all,
Just went out check out an '02 X-Type 3.0 Sport - the car threw a few codes (all relating to fuel injectors / misfires), the check light was on (my wee code reader wouldn't reset it), the motor shook a bit but sounded very smooth, no hissing but those hoses were all soft, air filter hose (or the short corrugated one on the top center) was missing any sort of clamp, no egregious oil spatters (that I could tell anyways), oil looked and felt clean, minor tennis ball size dent on front fender (no paint damage), but...
here's what stopped me dead in my tracks and had me saying "thanks for your time" before even driving...
When I looked around the suspension area on the back driver side wheel I noticed the mount for the sway bar - the actual part welded to the frame - had its business end broken off. No way to reattach the sway bar.
All the other issues seemed things I could probably happily tackle as I'm kind of into a project, but welding and/or fixing something directly on the frame scares the crap out of me. The car was cheap-ish - $2,700 USD - so my question is: how much to have that sort of thing fixed? Is it even do-able without affecting the title? Does it really even matter (could I just take the bar off and be done with it)???
Cheers!
- Brad
Old 04-19-2014, 01:19 PM
Received 2,183 Likes on 1,355 Posts
just weld it and weld a strap across the back for extra support. done it before any muffler shop with a welder can do it
Old 04-19-2014, 01:23 PM
bkmadison's Avatar
Thanks Brutal!
I should say, I don't have the bit that broke off so something would have to be made up. How should this impact the asking price for this car?
Old 04-19-2014, 01:25 PM
it shouldnt. its not safety related and if done properly, better than factory since they do break
Old 04-19-2014, 01:39 PM
bkmadison's Avatar
Excellent info!
What's an honest price for this sort of job? (Just need to know if we're talking a hundred, a few hundred, or just what.)
Old 04-19-2014, 05:55 PM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Brad,
I've moved your thread from General Tech Help to X-Type forum. Please post model specific questions about your X-Type here.
Old 04-23-2014, 09:49 AM
Originally Posted by bkmadison
excellent info!
What's an honest price for this sort of job? (just need to know if we're talking a hundred, a few hundred, or just what.)
purely subjective, to where you go. I first would get a bracket cut off from a wrecking yard since you said its missing and then go to several muffler shops since they crank up welders all day long
ahunt4
09-19-2015 06:46 AM
Lawrence
XJ40 ( XJ81 )
09-18-2015 02:03 AM
philwarner
09-16-2015 10:40 PM
avern1
09-08-2015 06:25 PM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: '02 X-Type Broken Sway Mount Fixable?
