Air Bag Light
Anyone got knowledge of error (fault) code U2017 I know it has to do with driver side air bags, but I have tried reset, clean and checked all connections under seats, side impact (crash sensor) wiring everything looks spot on, the car has only done 40,000 original, any help would do, I have just about given up all hope for MOT.
thank you to everyone in advance that can shed some light on this.
Lukie, U2017 is not listed in the Jaguar DTC lists for the X Type and all the airbag DTCs are in the Bxxxx set. Is your airbag light on and if so, is it giving a flash code when you turn on the ignition?
Generic listings of DTCs are often inaccurate when used for Jaguars and can be misleading!
rsa760041
23
09-25-2015 01:33 PM
