Air Bag Light
Old Apr 18, 2014 | 05:31 PM
JagYour's Avatar
Default Air Bag Light
Hi, my airbag light is on. I have code DTC 43. My question is will that be the crash sensor at the front of the radiator or will that be the drviers side sensor in the b-pillar? Thanks.
Old Apr 18, 2014 | 05:53 PM
According to my SRS list, Code 43 is the driver's side impact sensor at the base of the B pillar.
Old Nov 19, 2014 | 11:24 AM
lukie's Avatar
Anyone got knowledge of error (fault) code U2017 I know it has to do with driver side air bags, but I have tried reset, clean and checked all connections under seats, side impact (crash sensor) wiring everything looks spot on, the car has only done 40,000 original, any help would do, I have just about given up all hope for MOT.
thank you to everyone in advance that can shed some light on this.
Old Nov 19, 2014 | 02:21 PM
astromorg's Avatar
Lukie, U2017 is not listed in the Jaguar DTC lists for the X Type and all the airbag DTCs are in the Bxxxx set. Is your airbag light on and if so, is it giving a flash code when you turn on the ignition?
Generic listings of DTCs are often inaccurate when used for Jaguars and can be misleading!
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 2, 2015 12:48 PM
