Can anything other than tie rods cause this...
2002 Xtype 2.5 manual 166k mi on the odo.
Right front wheel has a TON of play when lifted off the ground and rocked at 3 and 9 o'clock.
12 and 6 are rock solid.
Feels just like a tie rod but is tons worse and the tie rod seems to not be moving, like it is the pivot point.
The whole hub/spindle assy is moving as a unit.
I just put on a new axle and control arm because looking at it when I rocked it there was a lot of movement at the ball joint. No change.
When I spin the wheel I don't hear any noise from the wheel bearing.
Received 3,825 Likes
Woznaldo
09-26-2015 11:02 AM
