Can anything other than tie rods cause this...
Old Jan 21, 2015 | 11:17 AM
wesmc's Avatar
Default Can anything other than tie rods cause this...
2002 Xtype 2.5 manual 166k mi on the odo.
Right front wheel has a TON of play when lifted off the ground and rocked at 3 and 9 o'clock.
12 and 6 are rock solid.
Feels just like a tie rod but is tons worse and the tie rod seems to not be moving, like it is the pivot point.
The whole hub/spindle assy is moving as a unit.
I just put on a new axle and control arm because looking at it when I rocked it there was a lot of movement at the ball joint. No change.
When I spin the wheel I don't hear any noise from the wheel bearing.
Old Jan 21, 2015 | 11:59 AM
wesmc's Avatar
oops....the new ball joint needed to set deeper than the factory one on the driver side. Now that the thing is seated deep enough and the pinch is tight the play is gone. Looks like it was the ball joint all along.
Old Jan 21, 2015 | 03:49 PM
Thermo's Avatar
Veteran: Navy
Wes, good to hear that you got it sorted out.
Poet
Feb 7, 2025 02:18 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Tahoe Dave
Sep 28, 2015 07:42 AM
Woznaldo
Sep 26, 2015 11:02 AM
