Hi, I need help!
Hi, hopefully someone with be able to help you with your "machine".
Here is a link to another thread that might help get you started: https://www.jaguarforums.com/forum/x...l-unit-208091/
Do you have the touchscreen controls or the hard button control unit?
What is the exact message that comes up?
What were the circimstances when it failed? Did it fail just out of the blue or maybe some other work was being done and then when you next drove the car that came up? Any other details you could share?
Help
Hello. I have a touch screen with climate control. The breakdown happened by accident, the car stood for a long time at freezing temperatures. The exact error `` communication failure '' appears immediately after clicking on the climate button.
Do you get the same communication error if you hit other buttons on the touchscreen? Or does it work for other functions? If other functions work at least you can start narrowing down where to start looking. Sounds like it might be a canbus issue.
How long did it sit out? You talking a a week or two or for months? Do you have any other issues with the car from sitting a while or does it otherwise run and drive well?
BlownKitty (10-23-2019)
Yeah....I know what you mean, but I look at it as a lot of people don't necessarily know much about cars or aren't familiar with forums. They know they have an issue and might not begin to even know what to ask. If it takes a little extra prodding, so be it I guess. That's what makes this forum so great compared to others. Someone is always willing to help someone else if they are at at least sincere. Plus, if everyone would just do a search on here and find their answer, it would be a lot more boring.
The following 3 users liked this post by Alfadude:
[font][font][QUOTE = Alfadude; 2143905] Вы получаете ту же ошибку связи, если вы нажимаете другие кнопки на сенсорном экране? [/font][font]Или это работает для других функций? [/font][font]Если другие функции работают по крайней мере, вы можете начать сужать, где начать искать. [/font][font]Похоже, это может быть проблемой canbus. [/font][/font]
[font][font]Как долго он просидел? [/font][font]Ты говоришь неделю, две или месяцы? [/font][font]Есть ли у вас какие-либо другие проблемы с автомобилем, когда вы сидите какое-то время, или же он хорошо ездит и ездит? [/ QUOTE][/font][/font]
Only the climate does not work, when you press the button, the climate control gives an error. All other functions: radio, volume and the screen itself work. He stood for a long time, but it was in the cold a couple of days.
How long did it sit? Long eough that you had to replace the battery? Does the car run and drive well now?
Was the heating and air conditioning working before it sat for a long time?
If it is saying it is a communication issue, like I mentioned previously, might be some sort of Canbus issue. I can't really give you any help o how to trace that down, but if you look inth eStickies section of the forum page you should be able to download the electrical diagrams. Might be able to at least give you a place to start to see how to trace it down. Could be as simple as a connection came loose or maybe corroded from sitting so long. I really can't say. Sorry I can't be of more help myself, but maybe someone else on here might have some ideas. This kind of issue is not something that is typically seen on here.
[QUOTE = Alfadude; 2143905] Вы получаете ту же ошибку связи, если вы нажимаете другие кнопки на сенсорном экране? Или это работает для других функций? Если другие функции работают по крайней мере, вы можете начать сужать, где начать искать. Похоже, это может быть проблемой canbus.
Как долго он просидел? Ты говоришь неделю, две или месяцы? Есть ли у вас какие-либо другие проблемы с автомобилем, когда вы сидите какое-то время, или же он хорошо ездит и ездит? [/ QUOTE]
загрузить фотографии сообщения
Help
[font][font][QUOTE = Alfadude; 2144286] Как долго он сидел? [/font][font]Долго ли, что вам пришлось заменить батарею? [/font][font]Машина сейчас работает и ездит хорошо? [/font][/font]
[font][font]Работали ли отопление и кондиционер до того, как он долго сидел?[/font][/font]
[font][font]Если он говорит, что это проблема коммуникации, как я упоминал ранее, возможно, это какая-то проблема Canbus. [/font][font]Я не могу вам помочь, как это отследить, но если вы загляните в раздел eStickies на странице форума, вы сможете загрузить электрические схемы. [/font][font]Может быть, по крайней мере, даст вам место, чтобы начать видеть, как отследить его. [/font][font]Это может быть так же просто, как если бы связь ослабла, или, может быть, она долго разъедала. [/font][font]Я действительно не могу сказать. [/font][font]Извините, я не могу больше помочь себе, но, возможно, у кого-то еще есть некоторые идеи. [/font][font]Этот тип проблемы обычно не встречается здесь. [/ QUOTE][/font][/font]
Hello, I checked the Dtc errors and got the following errors. CAN and ECM errors are scary. What to check? Thank you in advance. U1900
U2510
B1318
B1205
B1205
B2627
U2511
B1359
U2510
B1318
B1205
B1205
B2627
U2511
B1359
Help
[font][font][QUOTE = Spikepaga; 2144574] Привет, Ян. Добро пожаловать на форум. [/font][font]Я понимаю, что пытаться использовать Google Translate для общения с русским на английский сложно. [/font][font]Возможно, вам следует опубликовать фотографии полученного вами сообщения об ошибке, чтобы мы могли попытаться разобраться в нем. [/font][/font]
[font][font]загрузить фотографии сообщения [/ QUOTE][/font][/font]
DepchikSTR
10-10-2019 12:50 AM
