2004 X-Type brake lights
Hello I'm new to this forum,my son has a 04 x type that had some rear end damage. I replaced the driver side tail light. And the brake lights worked for 1 day and now only the middle brake light is the only one that comes on. When I turn on the head light the tail lights do turn on,but brake lights still won't turn on. I don't have a manual and can't find which fuse is the brake light fuse somebody please help?
Welcome to the forum Whymee,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Received 3,825 Likes
Whymee, if one of the brake lights come on, then all of them should come on. I would venture to guess that you have either some bulbs that are not fully seated or the backplane took a little bit of the accident and it has an internal failure. If you do some looking, you should be able to find a new backplane. I would first try pulling the backplane off and letting it sit in the trunk of the car as you apply the brakes and give the bulbs a little twist to see if you can make them light up. If they flicker for you, then this would confirm a messed up backplane. If they remain on, problem fixed.
