2004 X-Type brake lights
Old Mar 27, 2017 | 08:07 PM
Whymee's Avatar
Default 2004 X-Type brake lights
Hello I'm new to this forum,my son has a 04 x type that had some rear end damage. I replaced the driver side tail light. And the brake lights worked for 1 day and now only the middle brake light is the only one that comes on. When I turn on the head light the tail lights do turn on,but brake lights still won't turn on. I don't have a manual and can't find which fuse is the brake light fuse somebody please help?
Old Mar 28, 2017 | 02:01 AM
Welcome to the forum Whymee,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Mar 28, 2017 | 02:25 PM
Thermo's Avatar
Veteran: Navy
Whymee, if one of the brake lights come on, then all of them should come on. I would venture to guess that you have either some bulbs that are not fully seated or the backplane took a little bit of the accident and it has an internal failure. If you do some looking, you should be able to find a new backplane. I would first try pulling the backplane off and letting it sit in the trunk of the car as you apply the brakes and give the bulbs a little twist to see if you can make them light up. If they flicker for you, then this would confirm a messed up backplane. If they remain on, problem fixed.
Pirate
Apr 16, 2022 02:50 PM
Debbie Bean
Mar 16, 2022 03:35 PM
Rpach10115
Oct 6, 2016 06:45 PM
phreadd
Oct 6, 2016 10:10 AM
phreadd
Oct 5, 2016 12:06 AM
