Fault code P0037
Old 05-22-2009, 03:16 PM
Thermo's Avatar
Received 3,826 Likes on 3,145 Posts
paul, bank 1-sensor 2 is the downstream O2 sensor for the set of cylinders nearest the radiator. So, open the hood, follow the exhaust manifold down. You will see an O2 sensor near the motor. This is the upstream sensor. Keep following the exhaust down, go past the catalytic converter and the next piece that you see sticking out the side of the exhaust pipe will be the sensor you are after. I would first check the wiring to make sure that you haven't managed to damage the wiring. After that, replace the sensor. Odds are that will fix your problem.
If you need more help, just hollar.
Old 08-20-2010, 02:10 PM
kelv1962's Avatar
Default Poo37 code
I have this problem also my car is a x type 2.1 petrol 2003 i changed the downstream sensor and cleared code but the code still keeps coming back . How many downstream sensors are there on my car
Old 07-25-2018, 01:50 PM
rocket11's Avatar
People need to stop saying bank 1 sensor 2 is by the radiator, after installing the wrong one I found out it's NOT the bank near the radiator, it's by the firewall!!!!
Old 07-25-2018, 01:52 PM
rocket11's Avatar
Theres 2, unfortunately you got bad advice, bank 1 is by the firewall.
carlstev (11-12-2021)
Old 07-25-2018, 06:16 PM
Dell Gailey's Avatar
Yup, Thermo now owes everyone a beer, lol. Not often he has a brain fart.
The term "bank" refers to a grouping of cylinders in the engine. In "V" configured engines, as in V6 and V8, Bank 1 is the reference to the RH bank of cylinders, as the engine sits in the car and viewed from the driver seat (LHD). Bank 2 is the LH side. In the X-Type, the engine is turned 90 degrees to the right, that means Bank 1 is now the rear bank and Bank 2 is at the front.
Old 07-26-2018, 08:55 AM
iownme's Avatar
and to add.....
cylinders 1 3 5 are on bank 1 next to firewall. cylinder 1 on the left 3 in middle and 5 on the right.
cylinders 2 4 6 are on bank 2 next to radiator.
cylinder 2 on the left, 4 in the middle and 6 on the right!
Old 07-26-2018, 11:08 AM
wa3ra's Avatar
The first think to check for that "heater low" error is the fuse for the upper sensor, by the way!
Old 07-26-2018, 11:28 AM
Alfadude's Avatar
You can give Thermo a pass on that as at the time he posted that he was all but a noob on here. I'm sure he is a lot wiser in the NINE + YEARS since that was posted.
Old 07-26-2018, 06:06 PM
Ya think? Lol
Old 09-17-2018, 09:50 AM
ttodd's Avatar
OK Hi I'm Todd
I have an 04 XJR
Got the same P0037 code yesterday
Do the same instructions apply for my vehicle as the X?
this is what I purchased yesterday
Kwiksen Heated O2 Oxygen Sensor Downstream 234-4798 For 1999 2000 2001 2002 2003 2004 2005 Jaguar XJ8 XJR LNE1682BC OE Style
Old 09-17-2018, 10:25 AM
Thermo's Avatar
ttood, the concepts should be the same. The P0037 code is a generic code that is common to all vehicles. So, what applies to the X will apply to your XJR. The locations might be slightly different, but I am sure you can figure that out.
ttodd (09-17-2018)
Old 09-17-2018, 11:39 AM
ttodd's Avatar
Ok Thank U Sooo Much
Old 09-17-2018, 09:06 PM
iownme's Avatar
there is an XJ8 forum here too, if you need more info try posting there
Old 01-24-2020, 10:39 PM
Leg2006's Avatar
Default New o2 sensor in downstream, but still giving 0057
I replaced one of my upstream, and was stupid and used an universal o2 sensor for the downstream bank 2, and that's when I recieved the 0057 code. I purchased and installed a new sensor and am still getting the code. Getting smoke out the tailpipe when I never did before up till the universal. Also I didnt drive it but 2 mins with the universal sensor so couldn't have been long enough to heat every thing up. Not sure what options there are at this point.
Old 01-25-2020, 01:03 AM
Universal (read here cheap internet, usually Asian) sensors won't work on our X's.
Old 06-02-2020, 09:30 AM
mr moj's Avatar
Default re xtype 00037 code,
hi today my mechanic has tried to fit me a new sensor on the bank 1 sensor 2 but the new part has 4 wires and the old part only has three when he looked upstream to the next sensor that has 4 wires now we are confused. I ordered the parts from a Jaguar specialist in the part is a Bosch and I was assured this was the right part for The Bank 1 sensor 2. I have told the Mechanic to fit the new sensor anyway and to reset the fault code and see if this will correct the problem fingers crossed.
Old 06-03-2020, 01:31 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Sounds like the wrong part.
Old 06-03-2020, 02:18 AM
mr moj's Avatar
my mechanic got it wrong,there is four wires on both sensors.thanks
Quick Reply: Fault code P0037
